โJul-10-2013 06:58 PM
โAug-21-2013 05:52 PM
โAug-21-2013 12:06 PM
โAug-13-2013 09:32 AM
โAug-13-2013 08:44 AM
โAug-01-2013 12:28 PM
โJul-21-2013 05:26 AM
qtla9111 wrote:
Also, once all outlets are live, do small appliances detect the type of inverter that is being used (true sine, etc.)?
โJul-20-2013 08:06 PM
timjcarter9 wrote:Sandia Man wrote:
When plugging the shore power cord into an inverter, it will provide 120VAC to your entire rig. You will want to turn off breakers to your converter, AC, and even microwave oven as these will require an extra large battery bank and a sizable inverter. Additionally, fridge and water heater should be set to propane mode to keep from running your battery bank down quickly.
Exactly right and what I do. First turn off the breakers, put the fridge and hot water on gas, then plug in shore power to inverter. Works like a charm.
I have even done this with my 300 watt tailgating rig. 300 watts is plenty when used this way.
โJul-20-2013 07:58 PM
โJul-20-2013 07:54 PM
โJul-20-2013 05:20 AM
โJul-19-2013 07:59 PM
โJul-19-2013 06:56 PM
โJul-11-2013 08:22 PM
โJul-11-2013 05:34 PM
timjcarter9 wrote:skipnchar wrote:
IF you're powering everything from your inverter you need to EITHER carry a truck load of batteries or be running your generator MUCH of the time. Might be easier of you need that much power to just run off of the generator and forget the inverter.
Don't think he said that. Just wants power at all outlets.
So op be sure to know what you want to power. The less the better. If you can get away with a 300 - 400 watt inverter life is much easier.
