โSep-03-2014 08:25 PM
โOct-16-2014 05:47 AM
Bendder wrote:
That's true. I weighed mine before the instal and everything weighed 164lbs. Considering the only thing I lost in weight was the spare at 73lbs i have a net gain of only 91lbs. I will be putting my spare under the trailer (truck used 95% to pull it) i will gain some of the 73lbs back but not much. Planning on putting spare just forward of axles. Biggest drawback I see is moving the spare. If i could find a large enough and skinny enough tire as a spare I will stuff it back where it goes. Only thing stopping it is the width of tire.
โOct-15-2014 05:54 PM
โOct-15-2014 02:37 PM
โOct-15-2014 11:10 AM
โOct-15-2014 10:54 AM
โOct-15-2014 09:34 AM
Moderator edit to re-size pictures to forum limit of 640px maximum width.
โOct-08-2014 11:05 AM
โOct-06-2014 04:59 PM
Bendder wrote:
I had a 2" drop to the back of my truck at the wheel wells prior to this install with my old hitch with 1400LB WD bars and the front would drop 1/4". With the new PullRite the back of the truck drops only 1" and no change at the front. I find this odd as the weights have not changed The only thing I can account it to is the tongue length being longer?
โOct-06-2014 09:55 AM
โOct-03-2014 07:55 PM
โSep-04-2014 04:27 PM
โSep-04-2014 11:14 AM
Bendder wrote:Mark, welcome to Open Roads Forum.
---What I would like to know is the downward force at the pin by the diff and also the forces on the bearing rollers? any help would be appreciated
โSep-04-2014 05:57 AM
โSep-03-2014 11:34 PM
