Question on gas alarm
Guy_Roan
Can sewer gas set off the gas alarm ?
Guy
11 REPLIES 11
wa8yxm
Guy
Sewer gas is mostly methane and ___anes are explosive for the most part. So yes. We call it a "Propane Detector" but it is truly and explosive gas detector.
Methane (Farts/Sewer)
Alcohol
Gasoline
Butane
Propane
and a host of other things that go BOOM if the air/fuel mix is right.
kedanie
How old is the alarm unit? They are only good for about 5 years. They don’t cost a bunch, replace the unit if it is older.
Keith
Keith and Gloria
2013 Tiffin Phaeton 36GH
2012 Jeep Grand Cherokee Overland
USAF 1968-1976 Vietnam Veteran
Cummins12V98
MFL wrote:
Cummins12V98 wrote:
Guy
Don't know but a broken bottle of Tequila sure can!!!
Storing a bottle of Tequila, where it can move around/break is dangerous! Just when you really need it, you discover that you are OUT!
Jerry
It was a sad day as it was the good stuff.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
JimK-NY
MFL wrote:
I think the alarm going off, is likely the co detector. In that case anything having carbon monoxide would set it off.
Many times the propane and co detectors are incorporated in one unit.
Jerry
Not based on my experience. Every time I have had a false alarm the lights indicate it has been from the propane, not the CO, detector. I also have a separate CO detector. Except for using the test button it has never gone off.
MFL
Nomad II
Nomad II
Cummins12V98 wrote:
Guy
Jerry
Cummins12V98
Guy
MFL
Nomad II
Nomad II
Jerry
jkwilson
magicbus wrote:
Interesting question. From an article on gas alarms:
“If you buy a residential gas detector system, make sure you get the right one, O'Shea said. Natural gas customers should purchase a detector that can sense methane gas, while propane customers should purchase a propane detector.”
So it would appear that a propane detector such as we have in our RVs would not detect methane, which is a component of sewer gas.
Dave
That may be dated information. It’s hard to even find a unit that doesn’t claim to detect both propane and methane. My suspicion is that they can only label them with a particular gas if it was tested by a standards organization for that gas but that most of them in general detect flammable gases and vapors regardless of the label.
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
Bobbo
A few years ago, a poster to this forum had a dog with intestinal issues. He said that the dog regularly set off the propane detector.
Bobbo and Lin
JimK-NY
Over the years I have had all sorts of chemical set off the propane alarm. Those items have included hairspray, insect repellent, sulfurous emissions in Yellowstone, and caulk. The caulk was the worst. I used a large amount in the bathroom to add a slope to a small ledge. I had to disconnect the alarm for a great many weeks while it cured.
You may also get false alarms as the detector ages. The life expectancy of a propane alarm is about 5-10 years from the date of manufacture. Some seem to be overly sensitive or defective and give false alarms when they are relatively new.
magicbus
Dave
Current: 2018 Winnebago Era A
Previous: Selene 49 Trawler
Previous: Country Coach Allure 36
