Apr-19-2014 06:21 PM
Apr-23-2014 08:08 AM
ThorResidencyNewbee wrote:
I just installed my system myself about 2 weeks ago. I made a steel bracket and mounted that under my bumper. As others have mentioned, you need to have a solid mount for the brake cable to attach to. As for the plastic part in the tow bar arm, mine did the same thing. I tried every way I could think of to get it out but no luck. I ended up drilling a VERY tiny hole in it and slipping a hook tool in the hole and pulled the nylon part out. I then turned it around and reinstalled it with the hole facing inside the tow bar arm. Hope that helps.
Apr-22-2014 08:18 AM
Apr-20-2014 07:57 PM
Bobbo wrote:
The term "centered" has a little leeway. It does need to be mounted to something a lot more secure than your grill. I was wondering in your first post because you said it was mounted to the bumper. I thought that is one WEAK bumper.
Find a frame secured spot below the bumper within about 6 inches of centerline and mount it there. Or, make a secure bracket that you attach to the bottom of the actual bumper, and mount it to the bracket.
It very well may pull out of your grill, or pull your grill out.
Apr-20-2014 12:11 PM
Apr-20-2014 08:12 AM
Apr-20-2014 04:03 AM
