โMar-05-2014 08:49 PM
โMar-07-2014 01:31 PM
โMar-06-2014 06:53 PM
โMar-06-2014 11:05 AM
โMar-06-2014 10:25 AM
Hondavalk wrote:myredracer wrote:Hondavalk wrote:
the U bolt nuts are designed to hold tight. When you install them on the U bolt the Reese manual only has you install them till you have 3 threads showing. They must be pretty confident they're not going anywhere.
Thx, but I'm wondering how many times you can remove and reinstall these nuts and if they lose some of their grip? They seem kinda like they are pre-staked (if that's the right term) and not like a nylock nut. Not that I'm paranoid or anything, but I sure would not want one to come off while in transit!
http://www.reeseprod.com/content/contactus.aspx
Give them a call. They are very helpful
โMar-06-2014 09:33 AM
โMar-06-2014 09:04 AM
BarneyS wrote:badboy368 wrote:
i have been using the dual cam set up for many years and never drilled into the a frame at all. i have always just used the u-bolts with great success.
You must have the old style Dual Cam that uses large U bolts to fasten the cam arm brackets to the A frame. The new style, which has been out for many years now doesn't use the U bolts but instead bolts directly to the frame.
Barney
โMar-06-2014 08:36 AM
โMar-06-2014 08:30 AM
CampingN.C. wrote:
I believe the OP was referring to the U bolts that attach the chain to the hanger brackets.
You are very smart to NOT let the dealer install the DC brackets! I had to learn that the hard way!
โMar-06-2014 04:30 AM
โMar-06-2014 04:23 AM
โMar-06-2014 04:15 AM
โMar-06-2014 03:04 AM
โMar-06-2014 02:18 AM
