Rv Covers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
May-31-2022 05:28 PM
anyone have actual knowledge they could pass on? Thanks
- Labels:
Seeking Advice
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jun-05-2022 03:48 PM
2008 Sunnybrook Titan 30 RKFS Morryde and Disc brakes
WILL ROGERS NEVER MET JOE BIDEN!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jun-05-2022 03:34 PM
Every time I see a new cover go up, I make a mental note and then check on them throughout the year. It never ends well.
There's usually collateral damage to the rigs on either side too. If either of my neighbors ever put on a cover I'd ask management to assign me to a different space.
So I agree with Grit that they're a regional thing. And in some regions they do more harm than good.
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch • 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") • <\br >Toys:
- 18 Can Am Maverick x3
- 05 Yamaha WR450
- 07 Honda CRF250X
- 05 Honda CRF230
- 06 Honda CRF230
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jun-05-2022 09:56 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jun-05-2022 09:31 AM
scout dad wrote:
Thanks for the info, I should be clear that I will using them not only during the winter but all year long. My current trailer has a roof leak, I only wanted something to help prolong the life of roof when a under covered spot.
I have used a cover every winter since I purchased my trailer and the original owner used one also. The first summer owning my trailer I found a roof leak. Had it fixed, or so I thought, came home, covered it for the winter. Checked multiple times to insure it wasn't getting wet. All good, opened it up to go camping and on the first trip, had water in the same area as before. The cover kept the trailer from getting wet. Went back to the repair shop and after a day or so, they found an area under the fridge vent that was allowing water to get in. They fixed it and haven't had water inside since. But, I check the roof constantly.
I also disagree with the comments about chafing, paint rub, etc. Make sure the cover is a good one and is tight, use the belly straps. I have a couple tears, but the cover is 6 years old now. The only real issue is the rain gutters. I just bough new ones because using the cover, I have destroyed the old ones. $10 for a new set of 4.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jun-05-2022 06:46 AM
scout dad wrote:
I can't tell where is leak is coming from, water flows understand that, it seems to ending at the seam strip across the middle of room, almost center of window, I have looked but don't see any tears or rips or ? Unless it is a not visible ? Have TPO roof
Normal maintenance calls for you to inspect and re-caulk every seam and penetration in the roof every 12 mos if not every 6 mos. I do mine every 6 mos and re-caulk all the seams.
Get yourself a couple of tubes of Dicor self leveling caulk and clean and re-caulk all your roof seams and penetrations. You may not actually find the culprit leak but my guess is it would get fixed in the process.
Water is the biggest killer to RV's and causes a myriad of issues, many of which can't be seen. And then there's the collateral effects like mold.
Jeff - 2023 FR Sunseeker 2400B MBS
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jun-03-2022 12:58 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jun-02-2022 05:28 AM
You should fix your roof and not have to rely on a cover. Cover's aren't waterproof anyway. They breathe. While I have no idea what sort of leak you have, Dicor is cheaper and easier to apply than a cover. And you don't have continually put it on and take it off.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jun-01-2022 06:37 PM
quality covers are NOT waterproof, they "breath" both ways. you want moisture to escape and trying to get a cover that won't let water through to the "inside" would be prohibitively expensive. It will keep down the amount of water going through but it won't stop it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jun-01-2022 04:45 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jun-01-2022 06:42 AM
And they won't really protect from hail. They are a paper thin breathable material.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jun-01-2022 06:30 AM
2007 Alpenlite 34RLR
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
May-31-2022 07:38 PM
yes, they are kind of a pain to install and store, but do help keep the trailer looking good. And in the summer it does help keep the interior cooler
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
May-31-2022 06:46 PM
Mike
Payload 2476 Maxtow 13,800 3.73 Equalizer 4 Pt Sway Hitch
2017 Jayco Jay Flight 24RBS
Old TV, 07 Toyota Tacoma, Double Cab, Factory Tow Pkg, retired towing at 229K. (Son now owns truck)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
May-31-2022 06:27 PM
