RV roof UV coating. Worth it?
bucky
An accident has our 5er in the shop. They are trying to sell me roof UV coating while it's there. My research tells me the stuff is cheap, way cheaper than they are wanting and doable by me. Feedback would be appreciated. TIA
Puma 30RKSS
10 REPLIES 10
Veebyes
theoldwizard1 wrote:
Veebyes wrote:
What are they proposing to use. Could be a scam of using something as simple as 303.
A simple mild soap and water wash and spray down with 303 is cheap insurance. If the trailer is parked out in the SW sun, twice a year would be good.
This is true to a point. It was my method for over eleven years. Preventative maintenance. Even this year when I recoated the roof it was, I guess by the standards of some, in good condition. The 'roof pox' was not severe.
I looks good now. Hopefully it won't need another coating in the time left that I own it.
2007 Alpenlite 34RLR
bucky
Thanks everybody.
Puma 30RKSS
spoon059
Zero need. EPDM and TPO roof systems will last longer than most of the trailers they are installed upon. The problem areas are the seals and seams with the sidewall. If you are spending money on your roof, spend it getting new caulk installed. UV coatings are wasted money. They are designed to handle the UV light.
2015 Ram CTD
2015 Jayco 29QBS
C_Schomer
I even had a dealer tell me one time that all of those coatings are a huge moneymaker for them. Reflective coating really does work, though. I used Henry 587 on my roof and we got to Arizona in early October this year when I was still over 100 and the single 15 KAC did a great job and had long off cycles.The roof is still white, like before, but there must be tiny mirrors in the coatingโ€ฆ Ha! Henry 887 is supposed to be better yet. Craig
2012 Dodge 3500 DRW CCLB 4wd, custom hauler bed.
2008 Sunnybrook Titan 30 RKFS Morryde and Disc brakes
WILL ROGERS NEVER MET JOE BIDEN!
Lwiddis
Hengโ€™s works for me.
theoldwizard1
Lwiddis
As said, itโ€™s an easy do-it-yourself job. Since my TT is only 7.5 feet wide, I do it from a ladder.
Veebyes
Whatever, the roof should be thoroughly cleaned before anything goes on it. That will be 75% of the work right there.
Do it yourself. If the roof is in decent condition & only a few years old 303 will do. If it is 5-10 years old & had alot of sun exposure a recoating with something for the roof type will be the way to go.
Bumpyroad
what material is your roof? much profit for company
bumpy
Guy_Roan
I do mine once a year.
I wash it first and then put on the coating with a sponge mop.
It is an easy job and you can get the coating at most RV dealers by the gallon
Guy
