Slide out Awning removal
TWO_4_THE_ROAD
Hello: I want to replace the rubber molding that keeps the slideout from rattling when it's closed and we're on the road. On our last trip,the rubber part of the molding slid off it's metal bracket. Since I can't reach the molding when the slide is out and not when it's closed,I have to detach the roller part in order to access the outside wall of my trailer. Is there any tricks or is it pretty simple?
thanks
07 Forestriver Flagstaff 8528GTSS, 07 Chev,2500hd, D/A, , 2000 Mitsubisi Eclipse. ,DW Kathy,DD Maggie
2 REPLIES 2
Allworth
There are a number of U-Tube videos about replacing slide out topper fabric. The first part of each shows how to "pin" the roller so the spring is locked.
There is a hole at the end of the roller that you can insert a pin into (I used an old fashioned ice pick) and all the way through the roller tube. This is usually at the right end of the awning, but there may be a hole at each end.
Two people are absolutely necessary. You cannot reach both ends at once.
-Run the slide all the way out.
-Pin the roller.
-run the slide in, leaving it about 8" open.
-Unscrew the brackets holding the ends of the awning to the face of the slide.
-Lay the roller and awning up on the roof of the trailer.
Replace the seals.
Reinstallation of the awning/topper is the reverse of removal.
Put plenty of non-sag caulk under the brackets and in the screw holes.
Be very careful when pulling the pin(s).
Not hard; just fussy work.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
newman_fulltime
Need to know what make of awning
