Suspension Issue?
bama5er
I have a 2013 Sierra 38' fifth wheel. I have lost 3 tires due to complete tread separation in 4 years. I thought originally that I had a load rating (E) tire problem. However, after replacing all 5 tires with a F load rated tire I looked closer at the suspension. It seems I only have about an inch clearance from the top of the tire to the RV chassis. This seems very close. I have ALKO axles with Lippert Equi-Flex. My dealer says this is normal for my suspension. The issue is there is evidence (hole) where the tires have hit the bottom of the chassis. I would say this means that 1 inch is not enough clearance. If the tire running at 60-65 MPH hits a stationary object (RV chassis) that would cause the tread separation and a rough ride.
Question: Is there a standard minimum clearance for this?
31 REPLIES 31
bama5er
All tires show where they have hit the chassis. The right side is the worst and the side that the tires were on when they blew. That's way I'm thinking a suspension issue.
newman_fulltime
if clerance was the issue seems like all 4 tires would be hitting.
i have seen one tire hit if it goes over a bump or curb maybe in a turn
