โFeb-02-2014 08:45 AM
โFeb-07-2014 08:36 PM
โFeb-07-2014 12:05 PM
ripperoo wrote:wny_pat wrote:
I don't understand the thought process of some posters. I know that they are different sensor systems on the market and that some of the after market systems work much better. I also know that my 20 year old sensors work just fine. So to say its a waste of time and energy to make them work, or to say you'll know when it is full, well, yep you sure will and it just might be to late.
Yep, I agree. I did a lot of research here when I bought my used and then new trailer. To date sensors work perfectly, and I'm glad they do. Maybe I'm OC, but if it's there, I want it to work properly. It doesn't matter if I can also tell that the gray tank is full when it backs up into the tub. I want my sensor to tell me; and it does.
โFeb-07-2014 10:07 AM
โFeb-05-2014 05:26 PM
coolbreeze01 wrote:
The owner's manual for the Komfort recommended rock salt in the black and gray tanks to clean the sensors. Won't hurt anything to try it. Good luck.
โFeb-05-2014 12:33 PM
Jayco23FB wrote:
I have a friend who uses Calgon water softener in his black and gray tanks. He says it keeps the tanks clean as there is less residue when you empty the tank. I tried it last year and it seemed to work OK. I know when you mix the product with water it seems to make it more slippery and soap foams up better. Has anyone tried this?
โFeb-05-2014 09:12 AM
โFeb-05-2014 06:16 AM
โFeb-04-2014 07:56 PM
Cube58 wrote:fla-gypsy wrote:Dog Folks wrote:sch911 wrote:
Personally I wouldn't spend a dime trying to keep the tank sensors working. They're a lost cause in most RV's. Still it's pretty easy to tell when things are full. I don't need them....
X2
X3
x4
โFeb-04-2014 06:56 PM
โFeb-04-2014 02:07 PM
X2
X3
โFeb-04-2014 01:24 PM
โFeb-04-2014 11:33 AM
โFeb-04-2014 11:28 AM
โFeb-04-2014 07:00 AM
rondeb wrote:
Has anyone used a product like TSP to keep the hard water our or to clean the gray and the black tanks? I was wondering if you used TSP and filled the tanks half way on our way home, would it keep them cleaned
