If the sticking valve is close to the dump end, you can use the spray straw on a can of silicone lube to get lubricant to the valve. If it is some distance away, you can use a short length of automobile vacuum hose to make a long spray straw and direct the lubricant to the valve. Spray and then open and close the valve repeatedly and then repeat(better make sure your tanks are empty if you do this.
There's lots of advice and information in forums...
sometimes it is correct.
2011 Jayco 28.5RLS; 2008 Chevy 2500HD Crew Cab; Duramax/Allison; Pullrite 14k Superglide Hitch
