โOct-22-2019 08:02 AM
โOct-26-2019 11:49 PM
bpounds wrote:valhalla360 wrote:
...if it's important, it's a simple solution...
I don't believe it is a viable solution.
What is a done-every-day solution is to just buy the truck. Swap tires to whatever you want, and there is a pretty good market for take-off tires, so you'll get a portion of the cost back. Probably come out better than how a dealer would mark it up.
I actually inquired about the dealer changing out tires prior to delivery of a truck. They told me Ford does not allow them to do that. Now, I'm not saying I believe that. Just repeating what they told me. I didn't press him on it, but I'm sure they had trucks sitting there with all kinds of dealer added lifts and lights and bling. Calling a seller a liar usually doesn't help ones negotiating position.
โOct-26-2019 05:13 PM
โOct-25-2019 12:59 PM
cummins2014 wrote:JAC1982 wrote:
The Hankook's that came on my Explorer (purchased brand new) barely made it 30 as well. I mean I could have driven them a little longer but since I do drive in snow and I got a flat tire in one of them in November, I didn't want to mess around with borderline tires.
I hear more OEM's wear terrible more often then nought.
โOct-24-2019 02:36 PM
โOct-24-2019 01:27 PM
cummins2014 wrote:My truck was built in the aftermath of the big Firestone recall. I think Ford sourced the Goodyear off the shelf as they were quitting with Firestone. Did not get a chance to get some low ball special build. And yes I am in southern CA where it about never even rains so you can wear them pretty thin. My last set aged out but still replaced with top line Goodyear All Terrain with Kevlar. Going to have almost new tread exploring off pavement next month in DVNP.time2roll wrote:Might be the 1/2 ton ,towing a lightweight trailer . No idea. My 1 ton SRW trucks have never been that great on tires .
My OEM Goodyear Wrangler AT/S lasted just short of 90,000 miles.
โOct-24-2019 12:46 PM
โOct-24-2019 11:26 AM
โOct-24-2019 10:37 AM
โOct-24-2019 10:33 AM
bpounds wrote:cummins2014 wrote:
...wonderful OE tires that are worn out in less then 30K...
You've mentioned that a couple of times, so I guess you've had very bad luck with OEM tires. That has not been my experience at all. In fact, as often as not, I replace the original tires with the exact same tire, and I've done that for cars as well as trucks.
I might expect that if the truck/car I bought had the base trim level tires, which often are the smallest rated tire the designers anticipated. I never buy that version of a vehicle, so maybe that's why my tires do better??? :@
โOct-24-2019 09:50 AM
โOct-24-2019 09:47 AM
โOct-24-2019 09:44 AM
โOct-24-2019 09:34 AM
Grit dog wrote:
^ Well you actually agreed with me, but my point was why be so fickle as to try to specify the brand, model and born on date for the tires on a BRAND NEW truck?
That's just weird bro.
โOct-24-2019 09:08 AM
