Unless you can get the engine (any engine) up to operating temperature, and hold it there for about a half hour, you should not start an internal combustion engine. You need to get the engine and oil hot enough to boil off the condensation that will form in the first few minutes of the engine running. If you don't get rid of the moisture you can cause rust in the cylinders, valve train and other areas.
Leaving an engine up to six months without starting is usually not an issue. Longer than that and I'd pull spark plugs and fog the cylinders, change the oil and filters and fog the injectors (if possible) and fog the carburetor (if it has one).
Using a good synthetic oil also helps as it clings to metal parts better than dino oil and reduces wear at start up. Some oils actually have minuet magnetic particles to cling to the metal parts.
In any regard you should add a fuel stabilizer to the gas and be sure the tank is filled to the spout so there is little room for condensation. This is the biggest issue currently with long term storage. The 10-15% alcohol in todays fuels grabs water from the air and this water settles at the bottom of the tank causing all kinds of problems in boats and motorcycles that sit for long periods of time. Diesel is much less susceptible to this problem.
If possible, turn the engine over slowly without it starting after a long hibernation......remove spark plugs and turn with a wrench.
But......Lots of folks will simply tell you none of this matters. Just start it up and go! It's your dime...
RoyB
Dartmouth, MA
2021 RAM 2500 4X4 6.4L
2011 Forest River Grey Wolf Cherokee 19RR
520 w solar-200ah Renogy Li-Epever MPPT
