2016 Buick Enclave ALL AWD V6 3.6L cyl 6-Speed Automatic 6T75
Notes
Towable as is with speed and/or distance restrictions. Please see Owner's Manual for confirmation and procedures.
It is not recommended to tow this vehicle over 65MPH
The vehicle should be ran at the beginning of each day and at each RV fuel stop for about 5 minutes. This will ensure proper lubrication of transmission components. To prevent battery from draining while the vehicle is being towed, remove the fuse listed in the Owner's Manual from the fuse block, see Owner's Manual. This will need to be installed to restart vehicle.
To prevent the battery from draining while the vehicle is being towed, pull the fuse/fuses listed in the owner's manual. Follow owner's manual procedures.
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
