โNov-18-2013 02:00 PM
โNov-21-2013 11:16 AM
easttexan wrote:
The lights are permanently installed into the tail-light housing, then wired directly wired to a receptacle at the front of the car, then another cable connects it to the trailer receptacle on the motorhome. They are totally independent from the car. I plug the car into the MH just like it was a trailer.
โNov-20-2013 01:12 PM
โNov-20-2013 09:54 AM
easttexan wrote:
We tow our 2013 GMC Terrain and don't have any problem. I cut everything off, pull the fuse, then turn the key 2 clicks forward which allows me to put the transmission in neutral, then 1 click backwards, tow 250 miles and start the engine for 5 minutes, run through the gears a couple of time and do it all again. Our lights are independent of the car lights. I think we used Roadmaster Tail Light Wiring Kit, part # RM-155. This wiring kit will have independent bulbs and sockets that are mounted inside the tail lights. This will bypass the towed vehicles electrical system completely.
โNov-20-2013 09:30 AM
โNov-19-2013 10:02 AM
โNov-18-2013 07:36 PM
JC2 wrote:Chevytrkr wrote:
Okay, how do you Equinox owners tow your vehicles without draining the battery? I have yet to tow mine without the battery going down. I've pulled the No. 32 fuse, turned off everything in the car, key in the ACC position, gear in Neutral. I have a Roadmaster Even Brake system with the remote sensor in the motor home. I can go about 50 or 60 miles but then the sensor says the battery is low, and the car won't start again. When that happens, I disconnect the braking system and tow the car without it. Not safe, but necessary. Any suggestions or ideas of what I'm doing wrong?
Rich
http://www.bing.com/search?
q=toad+charge&FORM=MYMSNA&mkt=en-US&qs=n&sk=&sc=6-11&mymsn-headersearch.x...
โNov-18-2013 04:30 PM
Rich
