โJan-26-2017 01:13 PM
โJan-29-2017 05:40 PM
โJan-29-2017 05:28 PM
SpeakEasy wrote:
I have a 2010 4Runner - SR5 - not the trail model. It's the V6, 4.0L, 270 HP model and is rated for 5000 lb towing.
I'm using it with WD hitch, and the TT weighs in at 4300 lb.
This whole discussion of the use of a WD hitch with the factory receiver is pretty confusing to me and pretty concerning. I'll discuss that in a minute. First I'll respond to coolmom's original question.
I have had this setup for one season - the 2016 camping season. We took a few short trips around our part of NYS, and we took a longer trip through the Appalachians (West Virginia) and then another trip through Vermont. We probably towed more than 3000 miles total. Lots of it was in mountains. On our first trip I was watching the transmission temperature like a hawk. Based on what I saw, I decided to install a supplemental transmission cooler. Excellent decision! After that, our temps were fine in all conditions. On the steeper hills of WV we knew the trailer was there, for sure, but I never felt we were under powered. I didn't experience what some folks call white knuckle driving. The whole setup seemed pretty stable to me, even though I knew the trailer was there. I don't have any concerns about my towing experience.
I am short of cargo capacity, however. With the tongue weight and the weight of myself and one passenger, I'm at or a bit over capacity. Therefore, I put virtually no cargo in the SUV. It all goes into the trailer. It works for us, because it is just the two of us, and we do pack light. If you have more people and more gear, it will be a problem for you.
Now as to the WD hitch issue. That is a HUGE concern to me, and I wish I had known about this before I bought this vehicle. However, having read the entire thread here and most of the thread over on the 4runner forum, it looks as if Toyota may have revised their restriction. Apparently there was a time when they were putting a clause in the owners manual telling people not to use a WD hitch with this vehicle. That clause is NOT in my owners manual. There is no restriction, no warning, no caution, not a word about WD hitches. But I checked, and the receiver I have is, in fact, the small square one that is bolted to a cross member. It is not the extensive kind with arms that lead forward up to the side frame members. I am very disappointed to discover this, and I am not sure what to do about it. I will contact Toyota and ask them for some clarification.
-Speak
โJan-29-2017 05:03 PM
-Speak
โJan-29-2017 05:01 PM
shfd739 wrote:
I know you mentioned a 4Runner or Explorer but I'd also suggest an '03 -'07 Land Cruiser/LX470.
Rated for 650/6500 towing and has the same V8 as the pre 2010 4Runners. These aren't that they much bigger than a 4Runner and will easily go 300k+ miles with only normal maintenance. I'd have no qualms buying one with 100k miles and driving it till the wheels fall off. A few friends tow 5k lb hybrids with these and love them.
Some folks are leery of older vehicles but we're on our 3rd used 100k+ mile Toyota and none have given us any trouble or made us feel that they weren't up to the task of towing or going long distances. I like the money saved by buying used.
โJan-29-2017 04:52 PM
โJan-29-2017 02:27 PM
โJan-27-2017 07:11 PM
camp-n-family wrote:coolmom42 wrote:
So basically what I have to do is verify the type hitch that is on the vehicle. Sounds like the only definite way to do that is get under it and look.
The only hitch available on the newer 5th gen models (2010 and up) is the weaker integrated factory hitch so that's what it will have unless you buy used and the previous owner put an aftermarket one on. I would still imagine that would be rare.
โJan-27-2017 05:20 PM
โJan-27-2017 02:01 PM
โJan-27-2017 02:00 PM
xtech wrote:
Pulled a 25 ft TT with a 2005 V8 4runner. First used a standard weight dist. hitch. When pulling with a wind from rear and side was very scary, swayed terrible and I have been pulling trailers for 40 years. Replaced hitch with a Reese Strait Line sway control hitch and it solved the problem. I later went to a Tundra and 5th wheel and now F250. If it was me I would look for a nice older 4Runner with the V8. Ours was a Limited, very nice vehicle. If you do check the hitch. It was said that all V8 4Runners came with the frame mounted hitch instead of the one only bolted to rear crossmember, but the one I bought only had the one on crossmember so I had to replace it with a frame mounted one. Only problem as a tow vehicle is the short wheel base so don't go too long on trailer. Also not sure what my tongue weight was but I was over rear axle GAWR by a couple hundred pounds so watch that too.
โJan-27-2017 11:59 AM
carringb wrote:
One note on the 4Runner: The hitch is only designed for Class-3 towing, so they make the receiver tube shorter. Many heavier-rated ball mounts won't even fit! I'm fairly certain no WD hitches will work without modifications!
โJan-27-2017 08:32 AM
โJan-27-2017 07:42 AM
โJan-27-2017 07:12 AM
โJan-27-2017 06:51 AM
