To bad GM doesn't want to spend the R&D to upgrade the old Rat Motors.
My 96 7.4L has 410 ft/lb torque & 290 HP, but limited to about 3.8K RPM. The 8.1L/496 inch cubic inches of displacement, is rated between 320 to 340 horsepower and 440 to 455 lb-ft of torque depending on the model year.
Torque which isn't must different than the new Ford 7.3L : Horsepower is 430 at 5500 rpm, with 475 pound-feet of torque cresting at 4000 rpm
Think if GM decided to redesign the heads for direct injection and up the valve train to be rated to around 4.5K-5K RPM, it would match or exceed the Ford 7.3L
Toss in compression ignition, cam and it would be a screamer like my old L88.
Plus, think (more hope than anything) it might not be that dirty of an engine smog wise
But...GM hasn't seen enough demand to spend the bucks to to that...now if an independent would come out with an upgrade kit...I'd be instantly in line
-Ben
Picture of my rig1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
