Track molding
rodwood1
I was wondering if anyone has had this issue as they were installing track molding,I'm installing new 3/4 inch track molding around the entry door on my 27' 5er. As I am working the molding into the vertical straight track all is good but as soon as I get to the tight radius at the top to swing over the top of the door as I get several inches around the turn it begins coming out along the longer side or outside track. After many attempts and still the same outcome I thought I would check here to see if a heat gun may be my friend. Does anyone know the secret to installing around radius? is there a better Vinyl that will actually hold it in place around the radius?
4 REPLIES 4
4x4van
Also remember; don't try to pull it tight. I usually will try to do the opposite; push back towards the section I have already inserted, especially when going around corners. You want the inside radius to be "crowded" rather than the outside radius being "stretched tight".
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
rodwood1
So today I went to a local RV Repair shop the head mechanic when I was explaining the problem he interjected as I was explaining his experience was the same and they use vinyl glue and tape to hold in place until it holds. I came home and decided to try it again this time reversing the molding flipping it over starting at one of the radius. It held no problems I installed in minutes with no glues tape or heat. Guess I should have seen it from the start.....
drsteve
I'd try a heat gun.
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
guidry
Amazon sells two kinds. One is like you describe, the other is more pliable and easy to work with. I can't remember the good one name, sorry. I had the same problem and did some research when I came upon a Youtube video on the good one.
