- moishehExplorerMy kit has a circuit breaker. I am not sure of the size but fuses cannot handle any surges or harsh environments.
Moisheh - univmdExplorerI am not sure why fuse instead of circuit breaker, the installer installed the fuse, which I guess was supplied in the kit. I reinstalled a new fuse and towed successfully in dry weather. So not sure what happened yet. Maybe the fuse weakened over time and simply needed to be replaced? Thx for all the replies!:-)
- moishehExplorerWhy are you using a fuse in that line. Doesn't it call for a circuit breaker??
Moisheh - tenbearExplorerIf the toad battery is being charged from the MH and you let the toad battery get very low, maybe the battery was drawing more than 20A from the MH. That would blow the fuse in the charge line from the MH.
- Mandalay_ParrExplorerAlso looked for damaged wire. Maybe get an electrical person to help you if needbe.
- navegatorExplorerCheck the cable between the RV and the toad if they are electrical connectors, also check the RV connector, when they get wired they never seal them properly and water will get inside and cause a short, the other possible cause is a pulled out wire from one of the receptacles on the cable plugs causing the short.
This is for an electrical wire connection where there is an umbilical cord from the RV to the towed vehicle.
navegator
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 12, 2026
