Tach & Hour meter for portable generator
Dakota98
Just purchased this little gadget & am very impressed. It has a backlit display, shows RPM when running, shows hours when not, & even has a menu select for service. If you want to service the genny, say every 100 hours of operation, it will flash "SVC" on the screen when that number is reached & re-set itself for the next cycle.
Ebay Link
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
8 REPLIES 8
Dakota98
gotsmart wrote:
Here is another link for what the OP has posted:
linky
Good find.
I'd venture to say that may be the wholesaler that the Ebay seller is purchasing from.
I just purchase mine about 10 days ago for $22.49. Appears the Ebay seller has increased the price since.
2006 POLARIS ATV
USMC 68-74
gotsmart
linky
2005 Cruise America 28R (Four Winds 28R) on a 2004 Ford E450 SD 6.8L V10 4R100
2009 smart fortwo Passion with Roadmaster "Falcon 2" towbar & tail light kit - pictures
popeyemth
Thanks Dakota98
That will reach the dash on my old tractor easy.
"wine is a constant proof that God loves us, and loves to see us happy" ben franklin
pianotuna
Nomad III
Nomad III
Hi,
Here is one from Amazon that allows for battery replacement:
$13.00 Tach and Hour
Regards, Don
Dakota98
popeyemth wrote:
How long is the lead that wraps around the plug wire?
Thanks,Mike
Mike,
It's 57" long, from meter to end.
2006 POLARIS ATV
USMC 68-74
popeyemth
Thanks,Mike
Dakota98
pianotuna wrote:
Hi,
Nice unit. Similar ones are available on Amazon.
I saw those also, but this one has the "service" feature to it & also comes with a "replaceable" CR2032 battery. All others that I found, the battery was sealed & you could not replace it.
2006 POLARIS ATV
USMC 68-74
pianotuna
Nomad III
Nomad III
Hi,
Regards, Don
