โDec-31-2015 01:10 AM
โJan-01-2016 03:58 AM
skripo wrote:
I'm towing a 24', not 26.
โDec-31-2015 11:12 PM
โDec-31-2015 06:45 PM
JoeTampa wrote:The 2015 F-150 Regular Cab short box has a wheelbase of 122.4".
I am not sure that anyone would recommend an F150 to tow a 26 foot TT. Most would recommend an F-250, which has a wheelbase of 137" at minimum, or 18" longer than your Durango. I went from 109" to 153" and I can tell you that the inches matter.
โDec-31-2015 05:35 PM
โDec-31-2015 03:21 PM
skripo wrote:
Not in any particular order:
1) Perfectly level
2) Only feels like oscillation when being passed. Could be being pushed around.
3) 1000 lb bars
4) all air pressure at max. Trailer at 50 and TV is at 36 psi
Durango is not a jeep. It is based argest Mercedes SUV model. Wheelbase is 119.8", compare that to Ford F-150 at 122".
โDec-31-2015 02:44 PM
โDec-31-2015 02:28 PM
โDec-31-2015 10:07 AM
jerem0621 wrote:
I took the liberty to do a little research based on the numbers you have provided.
You state that you have a tongue weight of 850 lbs and you are using 1,000 lbs spring bars...you are within your tow rating and your GCWR...However you are WAY overloading your receiver.
Here is an excerpt from the 2014 Durango owners manual that addresses this issue.
So...
1) You have 130 lbs too much tongue weight
2) you have 270 lbs too much spring bar pressure (potential)
What does this mean?
Basically, your receiver is overloaded and more than likely flexing under the load/torque from the WD bars.
LT tires are great, The Sway Pro is a great hitch and the spring bars are appropriate for the tongue weight... but receiver flex will cause issues... really bad issues eventually.
In light of this I would crawl under the Durango and check the welds on the receiver for cracks.
Thanks!
Jeremiah
โDec-31-2015 08:46 AM
โDec-31-2015 08:21 AM
skripo wrote:
That is the one thing I am unsure about. The truck came with a tow package and 20" Goodyear Fortera HL (high load).
I still suspect them. I am thinking of changing them to a 10 ply but want to be sure it is the problem before I do.
The weird part is that it drives perfectly changing lanes at 65 MPH.
โDec-31-2015 08:19 AM
So...
Thanks!
Jeremiah
Sorry that table is for non WDH towing.
โDec-31-2015 08:01 AM
โDec-31-2015 07:48 AM
3oaks wrote:
I would look close at the receiver for a label or embossed writing on the receiver. The hitches that I have seen give two different ratings. One for use without a weight distribution hitch and another, much higher max rating when used with a weight distribution hitch.
โDec-31-2015 07:47 AM
So...
Thanks!
Jeremiah
โDec-31-2015 07:26 AM
