โMay-18-2014 08:53 PM
โMay-29-2014 08:46 AM
โMay-29-2014 07:56 AM
โMay-29-2014 07:38 AM
โMay-29-2014 07:25 AM
โMay-28-2014 07:02 PM
Ivylog wrote:
Guess you have not weighed your diesel PU as they are heavy on the front. Any PU will handle better with some weight in the rear. The OP's 900 lbs will come close to balancing out the axle weights which will result in better handling than a empty PU so he does not need WD.
โMay-28-2014 06:32 PM
ah64id wrote:Ivylog wrote:
If your 2500hd has a gas engine, then maybe. If it's a diesel you do not need more weight on the front axle. I would try it without and if you have a lot of porpoising then WD will help but you will have to adjust with more WD than you need to help the porpoising.
How does that matter? Spring rates are different and geometry still changes. The point is to get the weight back to where it was for suspension and steering, a diesel has the same issues as a gas engine.
โMay-27-2014 05:20 AM
โMay-23-2014 06:29 PM
โMay-23-2014 06:03 PM
bid_time wrote:MM49 wrote:So your telling me even though my 3/4 ton truck's receiver is clearly labeled for max 500 lbs tongue weight w/o WDH I should NOT run a WDH anyways? You don't mind if I laugh and move on do you?bid_time wrote:Sorry KD4UPL is correct on this discussion. The weights he is describing would balance a DW truck about perfectly. WDH is very hard on a RV frame and suspension. I wouldn't run it unless it is needed, ie 1500 truck.KD4UPL wrote:Bad advice, just because you don't need one doesn't mean he doesn't need one. My 3/4 ton reciever is clearly labeled, 500 lbs max w/o WDH. The best advice he got was for him to read the label on his receiver. Much better than the "I don't need one so neither do you" advice.
You don't need one. Your tongue weight is below the hitch's rating. Save your money.
I tow up to 14,000 pounds without a WDH with my dually and the ride and handling are great. My hitch is rated for 1,700 pounds of tongue weight without a WDH.
MM49
โMay-23-2014 09:05 AM
โMay-23-2014 08:56 AM
MM49
โMay-22-2014 07:38 PM
โMay-22-2014 09:57 AM
โMay-19-2014 07:11 PM
