What cars can be towed 4 on the road
somertime
I have been searching the web trying to find what car I should get to tow behind a Class A..I don't want to fool around , I just want to be able to hook and on hook, easily. Any advice from you experienced folks would be appreciated.
6 REPLIES 6
janstey58
Edit on Bobbo's info above, be sure you are hitched to your MH before you do step 2!
Jeff and Kim
2015 Fleetwood Discovery 40E
Freightliner Chassis 380HP DP
2012 Ford Escape Limited Toad
Bobbo
Subaru manual transmission fits your criterion. Subaru automatic transmission requires a full trailer since it can not be towed with ANY wheels on the ground.
1. put in neutral
2. release parking brake
3. turn key 1 notch from LOCK to OFF
you are ready to tow, no speed restrictions, no distance limits, no pre-towing procedure of gears to go through.
Bobbo and Lin
Triker33
Do you want a car, SUV, truck, 4W, 2W, under 4K lb, 5K, 10K auto or manual transmission. New or used in what price range?
There are many choices to pick from.
Many may need just a fuse pulled or needing engine ran for 5 minutes every so many hours.
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
rockhillmanor
Not all cars can be towed 4 down per manufacturing specs.
Whether a car can be towed 4 down is found in the car's Owners Manual. Look under "Recreational Towing".
It will show your right there whether it can be towed 4 down or a dolly is needed or it can NOT be towed.
So either find a car you like and look at the owners manual
OR
use the above info and search thru the ones known to be able to be towed 4 down in the Motorhome Magazine.....which i would still check with the owners manual of the one you decide on.
Good Luck in your search for that perfect toad!
Tom_Barb
Any of them can be towed 4 down, it's just a matter of how much equipment you must add to do it.
enblethen
Do you want new or used?
Motorhome magazine puts out "Guide to Dinghy Towing" It came out in April 2014.
Here are some of the towing guides through a dealer.
Towing Guides
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
