โJul-22-2017 09:52 AM
โJul-22-2017 04:38 PM
TNGW1500SE wrote:
I wish I didn't have to worry about someone throwing a cigarette out on the road but people are generally stupid. ๐
โJul-22-2017 04:10 PM
RedRocket204 wrote:
I live in a forested area too and fire mitigation is a BIG deal. I don't ever recall reading anything about suggested ways to mitigate forest fires that involves wetting down an area. What is generally suggested is a fire mitigation zone, a cleared area from any structures you don't want to burn. That usually includes removing any trees and brush within 30 feet of structures and then trimming tree limbs that are within 10-12 feet of the ground in a 50-100 foot parameter around structures. We are told that if you choose not to fire mitigate, then the likely hood of your structure being saved by fire fighters is a lot less. That, and they may consider not trying to save your structure as you never took the proper fire mitigation recommendations.
My opinion would be that wetting down an area will quickly evaporate with an approaching fire and probably not do much good. You would need very high volumes of water to be successful. It may be a waste of money... but don't take my opinion as fact. And, most likely I do not live in a similar environment as you.
Please do yourself a favor and look into proper fire mitigation and make the necessary changes that are recommended for your area. If you can't find anything, I'm sure a call to the local fire department can provide lots of good information for you on how to proceed.
โJul-22-2017 02:21 PM
โJul-22-2017 01:03 PM
mobeewan wrote:
There is a grey PVC pipe for water use and it is supposed to be UV resistant for outdoor use. You will have to get it from a plumbing supplier.
โJul-22-2017 01:02 PM
myredracer wrote:
......Either copper or galvanized steel would work with galvanized probably being the better for heat resistance and impact damage.
myredracer wrote:
......What about a booster pump if you have 120 volts there?
โJul-22-2017 10:42 AM
โJul-22-2017 10:33 AM
โJul-22-2017 10:32 AM
โJul-22-2017 10:29 AM
โJul-22-2017 10:07 AM
Bud
USAF Retired
Pace Arrow
