Where to get Replacement Wheel Bearings -Old Camper
GaryS1953
Hi All - I have a 1996 Coachmen Catalina small 5th wheel, 210RB. I'm not particularly mechanical, but for the last couple of years I've repacked my own wheel bearings. Today I had one seize up and come apart, so I need a replacement, and I thought I would replace them all. Trouble is, looking online, I can't figure out how to order them. The old one that I've gotten off is completely destroyed and without a part number. E-trailer only goes back to 2010. Anyone have any ideas who I could order them from that would know what I need?
Gary in Michigan
2014 Chevy Silverado 1500 Double Cab 5.3 Liter V8
1996 Coachmen Catalina RB210 21' Fifth Wheel
495 Watts Solar, 40 AMP Renogy Tracer MPPT Controller,2 GC2 6V Batts.
17 REPLIES 17
time2roll
etrailer.com or a good auto parts store. 1996 is like brand new in the wheel bearing business. I thought it might be 1950s or prior.
Trackrig
Pull apart one of the others that's still in good shape and look for the part numbers.
Then, order them from this guy:
Dave Stark
800/409.3632
760.799.2091 - you can send texts to this number
75090 St. Charles Place, Suite B
Palm Desert, CA 92211
He has fast service and very good prices. He ships in USPS flat rate boxes which also saves money. He does bearings and seals.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
JRscooby
Look real close at edge of bearing. Most times there is a name and number. If can't find that, take the races to a trailer parts/repair shop. Note; if you don't tell the bearing it is going on a RV, it will never know. Much more likely to get what you need from a shop that does not fix toilets and stoves. You are looking for trailer parts, not RV parts.
