Would this treatment help on the black water tank
rickhise
Do you think using dawn dish detergent. With occasional squirts through out your week. End would lessen any side wall tank build up, the. Finish the bottle off on your rinse?
Doesn't seem to complicated an inexpensive
Opps I didn't mention black water tank.
29 REPLIES 29
rondeb
oops
rondeb
We use a capful of Calgon after each dump. It is a water softener and helps keep your tanks clean from Build up
Dtank
vic46 wrote:
Campinfan wrote:
I add some dish soap every now and then and it seems to help flush the junk out of the black tank easier. I use to use the geo method but cannot find the calgon water softner stuff.
20 Mule Team Borax replaces Calgon. It does the same job. Mix the soap and Borax in warm water and then dump into the black tank. No stick and no odor.
Vic
"20 Mule Team Borax replaces Calgon" = not really..:(
"It does the same job." - maybe, but not as well.
*LIQUID* Calgon is available in most stores where you (previously) purchased Calgon powder.
IMO - neither Borax or White King water softener are good substitutes for Calgon - but if those 20 mules ring your black tank chimes, cool!..;)
The GEO Method is alive and well - and EZ...:C
Sfla2
Walmart has the liquid just as good
98 Coachmen "C" Santara Model FL (Front Lounge) 30.4
Ford V 10 Super Duty (same as E 450)
ktmrfs
djousma wrote:
My wife washes dishes with Dawn. The problem we have is that it is super concentrated. I believe that soap suds "live" in my gray tank, and as such continually foul my sensors so that they give false full readings. I often think about creating a highly concentrated mix of TSP to add to about a 1/2 full gray tank BEFORE we leave on a long road trip to "wash" the tank. I've never gotten around to it however.
same experience with dish soap. we've switched to another brand. Dish soap is made to foam up so it "looks good", doesn't need to in order to do it's job. Dishwasher soap, laundry soap, especially the HE stuff doesn't foam up much at all.
We live in an areas with very soft water, so not sure calgon does much good. But we use the happy camper stuff in the grey/black tank, put it in before we leave home. Then just before we leave for home, I put in liquid laundry detergent, enough for one load of laundry in each tank. let it slosh around on the way home, then dump the next day at my home dump station. If we won't be heading home and have near full tanks, or are going to another campground, do the same thing then dump along the way after stuff has had time to slosh around.
I avoid dumping the black tank as I leave a campground like the plague, unless it is the only option. Grey tanks, ok, but usually if I have stuff in the black, leave the greys full and use them to backflush the black tank when I do dump.
we camp close to 3 months/year and after 4 years I have never had trouble with excessive tank buildup.
2011 Keystone Outback 295RE
Campinfan
Thanks for the info about finding it at Amazon and about Borax. I was just looking at Borax the other day at Dollar General and was wondering if it was like Calgon.
When I put dish soap in my black tank, I still added some Odorloss or something like that....it did not foam up at all but I think it helped make things a little slicker.
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
Vulcan_Rider
sdianel wrote:
for the gray tank we use 1 cup of Dawn Platinum
Another case of WAY overkill.
Given the recommended concentration of Dawn to make a good working solution, a cup would be enough to treat about 500 gallons.
Since it is likely that your holding tank is not over 50, you are using about 10X too much.
sdianel_-acct_c
we use Thetford black tank chemicals. Worth it. No smell. I don't think Dawn dish detergent by itself will mask odors in the black tank. My brother in law used Lysol but I don't like the smell of it. When it's hot out we use extra chemicals.
for the gray tank we use 1 cup of Dawn Platinum and 1 cup of Borax mixed with hot water. No gray tank smell and clean tank.
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
beemerphile1
vic46 wrote:
SoundGuy wrote:
You haven't specified just which tank you're talking about but if it's the trailer's black water tank I'd suggest you familiarize yourself with The Geo Method.
Read the title of the thread again! BLACK TANK!
Read the OP again where it says;
* This post was edited 07/01/15 09:23am by rickhise *
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
vic46
[COLOR=]Never argue with an idiot. You will be dragged down to their level and then beaten with experience.
vic46
Vic
2gypsies1
Don't leave your gray tank hose open. Let it fill up each time and you'll be good to go. There are plenty of soap products in there - hand washing, showers, dishes.
Don't throw garbage or coffee grounds or grease down the drain. Take a used paper towel and wipe things off before washing them.
In 16 years of full-timing and using the RV daily, we never had a problem with either the gray or black tanks. We didn't use any additional 'stuff'.. just plenty of water.
Full-Timed for 16 Years
.... Back in S&B Again
Traveled 8 yr in a 40' 2004 Newmar Dutch Star Motorhome
& 8 yr in a 33' Travel Supreme 5th Wheel
beemerphile1
We accomplish a similar thing but without wasting any dish detergent.
We seldom have full hookups so conserving gray water capacity is necessary. We set a plastic tub in the sink to wash dishes and then pour the wash water into the black tank via the toilet.
rickhise
I was thinking the suds was the purpose for breaking down the build up on the tank?
