โFeb-12-2015 09:17 AM
โFeb-14-2015 05:29 AM
BurbMan wrote:
They may be wires coming from the converter that charge the battery when plugged in. Typically the ground is run through the frame (like a car) so chances are those are both (+). If you have a multimeter, set it to ohms and see if you get any continuity between either of those wires and the frame, just to rule out them being grounds. You may want to crawl around a little and see what you can find out before connecting them. Or maybe call the guy you bought it from and ask him?
Oldman....ya gotta lay off the hooch this early...what "hotties below the picture?"
โFeb-13-2015 04:59 AM
โFeb-13-2015 03:33 AM
โFeb-12-2015 06:27 PM
โFeb-12-2015 03:57 PM
โFeb-12-2015 10:37 AM
โFeb-12-2015 10:35 AM
โFeb-12-2015 10:31 AM
โFeb-12-2015 10:21 AM
BurbMan wrote:When OP first posted, his url was different...would not display. I went to his url and saw 4 hotties below his picture.
โFeb-12-2015 10:18 AM
โFeb-12-2015 09:48 AM
โFeb-12-2015 09:36 AM
โFeb-12-2015 09:20 AM
