Batteries and Inverter Installed
BurbMan
Hey guys I know I asked a bunch of question on Lithium, but in the end I decided to go with (4) 6v batteries from Costco. I appreciate all the feedback on the forum.
So the trailer has a steel-floor compartment between the landing jacks and forward of the basement that the perfect spot. The camper was built with 1-12v batter in the forward curbside compartment with the jack hydraulics.
I stole the idea from another poster that commented on my other thread and found a plastic storage tub at the home center that would fit 4-6v batteries.
I used #4 wire between everything.
I added a vent hose and routed it to the original vent in the front of the trailer. I also added an intake at the bottom of the box with a hose that draws fresh air from below the floor.
I installed the Xantrax 600W inverter and 15a trandfer switch on the wall right above the batteries:
Inside I added the Xantrax remote, battery gauge and Progressive Charge Wizard to the switch panel by the door. The trailer already had a PD 9260 installed, so all I had to do was add the remote pendant.
25 REPLIES 25
deltabravo
A Victron Smart Shunt or BMV-712 should be your next upgrade - they are a smart battery monitor because they monitor amp hours consumed.
I've been using amp hour monitors since the 90s when they were invented.
Here's the BMV-712 install I did in my previous RV
BurbMan
Checking water levels on the TT was a PITA because the batteries were on the tongue behind the propane tanks, here they are easy to access and check.
Lantley the issue is the converter/charger...some cheaper OEM models will overcharge the batteries and that's what causes the water loss. This 5er has a Progressive Dynamics 9260 so I'm not worried about overcharging.
Checking batteries weekly is for the retired guys that need something to do....I check mine 2-3x per season and never had any issues.
BTW if you don't boondock, there's no need for this capacity. We like to camp at music festivals and they never have hookups and often prohibit generator use, so I like to get through a weekend on batteries.
pianotuna
Nomad II
Nomad II
Lantley wrote:
Currently I have AGM's and a small inverter powering a TV and nothing else.
Very simple install as I seldom boondock and I have a built in Onan 5500 if I really want power.
What had me questioning AGM vs. typical lead acid is the idea that water levels need to be checked once a week. If once a week monitoring is truly required, than it seems AGM's are the only way to go regardless of cost because once a week is a cumbersome task to me.
Before I went with AGM's I had lead Acid and I checked maybe 3-4 times a year at random intervals, But I was not running an inverter.
Is it that running an inverter necessitates weekly checks? Is it the size of the inverter and frequency of use that factors into weekly water checks?
Or are weekly water checks not necessary?
A small inverter has little or nothing to do with checking fluid levels on wet cells. What does is poor converters.
What size wattage is the inverter?
I had wet cells--but got tired of checking water levels laying down in snow.
Regards, Don
Lantley
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
BakFlip,RVLock,5500 Onan LP,Prog.50A surge,Hughes autoformer
Porta Bote 8.0 Nissan,Sailun S637
Correct Trax,Splendide
StirCrazy
Navigator
Navigator
Lantley wrote:
I'm no battery guru and I'm not challenging the advice given.
However, checking battery level weekly seems like a lot to go through.
In reality I can never see ME checking the battery level that often.
For that reason alone I would opt for AGM's.
I check my batteries 2 or 3 times a year if there new, begining of camping season end of camping season and once and a while 1/2 way through storage. if you have the factory WFCO converter it might be better to check them once a month, but a good quality charging system on new batteries shouldnt need that frequent of checking.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
BurbMan
TechWriter wrote:
OP, what breaker/fuse are you using between the batteries and inverter?
I have a 60a circuit breaker on the positive lead between the battery bank and the inverter. A #4 wire can actually handle more than 60a, but 60a @ 12v = 720W which is more than the inverter is rated for, so the inverter will shut down before the breaker pops in case of overload. The breaker is there to protect the wire in the event that the inverter malfunctions.
Xantrex states that #0 wire is recommended to minimize voltage loss over distance. They also have the same install guide for the 600w, 1000w, and 2000w models. Being that the inverter is ~3' from the batteries, voltage drop over distance was not a concern.
Lantley, the advantage to AGM is that they don't need to be vented, but also cost about double what you pay for a 6v GC2. The install worked out good for me because there was already accommodation for an external battery vent that I could connect to. Keeping the batteries in a storage bin not only supports venting but also keeps anything from accidentally contacting the battery terminals. I can store stuiff on top of the bin, it has a sturdy lid.
corvettekent
theoldwizard1 wrote:
You need to check the water in the batteries at least once a week. Hot weather and multiple discharge/charge cycle will cause evaporation. Depending on how much you use your RV, you probably need to clean the batteries every 3 - 6 months.
Our four FLA 6 volt golf cart batteries only use one pint each per year. We use our trailer 120 -150 days a year. They are seven years old and there is no corrosion on the terminals at all.
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Companion Hitch with pucks. Hadley air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
Lantley
Grit_dog
Nomad III
Nomad III
Lantley wrote:
With that in mind what is the down side of using AGM'S Price?
IMO, yes, that's the only downside.
I'm not one to be terribly OCD about batteries. I probably do a better than average job maintaining batteries than alot of people, but not interested in treating them like your first newborn child!
AGMs just eliminate a maintenance issue, which in turn also makes them a better fit sometimes for "custom" applications.
12thgenusa
Unless you have a faulty charger or abnormally hot weather, I think you'll find that you'll only need to add water every three to six months. Mine stays on solar 365 days a year and I add water at the beginning of the season and just before it goes to storage for the winter. Check more often until you are confident of the interval.
2007 Tundra DC 4X4 5.7, Alcan custom rear springs, 2009 Cougar 245RKS, 370 watts ET solar, Victron BMV-712, Victron SmartSolar 100/30, 200AH LiP04 bank, ProWatt 2000.
Veebyes
I guess the downside of AGMs is the price however there are plenty of upsides starting with the length of service life which should be 2-3 times that of wet cells. There is NO checking for levels on an AGM. There is no concern about venting. The only checking to be done is perhaps connections at the battery. You can locate an AGM anywhere you please. They don't even have to be mounted upright. Mount them INSIDE if you wish. In boats it is not uncommon to find AGMs located in spaces inside the cabin. They can withstand a deeper discharge, & recover, than a wet cell. They accept a bulk charge rate better than a wet cell. They lose less charge in storage than wet cells.
Yes, the wet cells are cheap on the initial setup but over time are they a better way to go? My first AGM, a 4D case size, had a 215AH rating & gave a service life of 9 years. Every year it sat in storage for over six months with NO trickle charge or top up charge.
2007 Alpenlite 34RLR
Hurricaner
Costco use to carry us battery 6 volters which were excellent. Not sure who makes the ones they sell now but they have terrible reviews. If you go to there site you will notice there are no reviews now but last time I checked there where plenty and none were good.
Sam
Sam & Kari
Hurricane, Utah
2019 Winnebago Sightseer 33C
TechWriter
Lwiddis wrote:
Using #4 wire should mean close to no loss.
For a 600W inverter #4 is the minimum size. The Xantrex ProWatt 600 manual recommends 0 AWG (1/0) wire.
www.rvSeniorMoments.com
DISH TV for RVs
pianotuna
Nomad II
Nomad II
A properly cared for flooded bank may outlast an AGM. It is hard to beat six volt golf cart batteries wired in series.
However the "properly cared for" means checking water levels regularly, always cycling to 100% state of charge, and keeping corrosion at bay.
AGM are more expensive than flooded. Like flooded, they should be recharged to 100% on every cycle.
I chose to move to reconditioned telcom batteries which are an AGM format.
My favorite battery is SiO2 which are a subset of AGM. That particular format does NOT have to be recharged to 100%, but should be fully recharged once every 30 cycles.
Regards, Don
