120 Volt receptacles in Motorhome
Profcadd
Hello friends. Here we are my wife and I, on our first spring getaway since our winter trip in Florida. Several of the 110/120 volt receptacles are dead. Including the electric water heater. Other receptacles are ok. The circuit breakers have not tripped. I switched them off and on again. No luck. In my 36 years of RV'ing I have never experienced this type of problem. I am stunned? Hope there is an electrician reading this with some advice.
See profile for motorhome info..... Thanks
Retired Professor of C.A.D.D
2008 Itasca Latitude 39W Gas pusher with GM Vortec 8.1 L & Allison 6 speed.
In Tow: 2016 Chev Equinox LT. Blue Ox tow bar, Patriot braking etc.
Companion: My Wife Rita
16 REPLIES 16
Profcadd
The problem is over for now. I do think the problem is in the pedestal. Just to be sure I shall replace the plug when I get back home on Tuesday. I have ordered a Camco 50-Amp Power Grip Replacement Male Plug.
Thanks again for your valued input.
wa8yxm
Unless you have something plugged into the pedestal GFCI it should not trip (less you press the test button) nor should it affect your RV at all.
Possible there is a wiring issue in the post that is causing all the problems.
CA_Traveler
I'd guess that the pedestal GFCI caused some kind of electrical transient which effected your rig. It sounds like your rig is OK.
2014 Grand Cherokee Overland
Bob
Profcadd
You are correct. The GFCI's in the coach tripped again. I went to the pedestal and had to reset their 15 amp GFI, yet I am running 50 amp. This is weird....
CA_Traveler
The most likely cause was the pedestal plug due to high usage. Second most likely is your cord plug.
Bob
Profcadd
Thank you all for your valuable input. Yesterday the 2 GFCI's would not reset.
Today I changed over to 30 amp at the park pedestal and then back to 50 amp. went inside and was able to reset both GFCI's All is now up and running. Maybe it is a fault in one of the power legs as wa8yxm suggested. Any ways, thank you all again. I have resolved many problems over the years with the help of this forum.
wa8yxm
Additional. The water heater did you measure voltage or is it just "NOT working on electric" There are several reasons for the latter.
On outlets.. If the specific outlets NOT working are Kitchen, Patio, Over the dining tabel, and bathroom.. Check the GFCI, (usually in bathroom) it may be tripped.
wa8yxm
Let me guess. 50 amp RV?
The reason I say this is 50 amp rigs have two power "legs" and you may have lost one leg.. tHIS CAN BE DUE to a tripped breaker (main) in your RV or at the park pedistal or at the park main service box (Distribution panel) or a bad wire or several other issues.
If your RV is properly wired then when this happens ONE A/C will work, the other will not.
Page 2: A non-joke I often tell is this, Many RVers have a few screws loose.
Here are SOME of the loose screws I have found in my RV.
Power inlet: (one screw on one leg causing what you see)
Circuit breakers.. Several in my RV one took over 3 Full Turns to tighten (ouch, fire hazard in fact).
And on another rv ALL SIX screws inside the Marinco outlet (And on still another just one, the neutral).
And I've seen bad connections in the park power pedestal and main distribution panel.
And you must remember when reading this.. I DO NOT DO THIS FOR A LIVING... If I did, I'd have much larger numbers of rigs I've worked on.
gatorcq
I vote for not enough information is being provided by the owner.
Dale & Susan
DaGirls II Rv - Dakota & Tilly Traveling Companions.
2008 Alfa Gold, 2015 Ford F150 XLT
Roadmaster and Air Brake System
1600 Watts, Magnum Inv/Chg&Solar
800 Lithium Battery
DaGirslRV Blog
tenbear
Another vote for a tripped GFCI.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
horizon36
Check the push to reset breakers on your inverter. One is probably tripped and will cause the problem you are having.
Live Long and Prosper.
Home is where we park it.
FT since August 2010
'02 Itasca Horizon 36LD
'02 Jeep GC toad
westend
Water heater and receptacles should be on different circuits. Check for GFCI trip, both inside and outside. Water heater may have a switch inside and one outside in compartment.
If water heater was powered on with no water in tank, the element will be toast.
'03 F-250 4x4 CC
CA_Traveler
If it's a 50A rig then one of the two legs could be dead. Could be anything from the plug to the CB panel. Get it checked.
Bob
