โApr-11-2015 03:21 AM
โApr-11-2015 07:52 AM
โApr-11-2015 06:53 AM
โApr-11-2015 06:29 AM
westend wrote:
The converter 120 AC should be grounded through the ground wire in the supply wiring. If you wish to ground the chassis separately there is nothing bad about that but the chassis of the converter and the circuits are all connected inside the converter to supply ground.
I also commented in your other thread about using copper pipes as a ground plane, not best practices.
You should establish a new ground point for your electrical service.
โApr-11-2015 06:16 AM
โApr-11-2015 05:00 AM
โApr-11-2015 03:49 AM
โApr-11-2015 03:41 AM
