โMay-26-2020 06:58 AM
โMay-30-2020 10:26 AM
โMay-30-2020 09:50 AM
SlideInDad wrote:
If the IOTA45 converter is simply properly bonded to my house 120V what purpose would the chassis ground serve?
โMay-30-2020 08:23 AM
โMay-27-2020 09:17 PM
โMay-27-2020 06:54 PM
SlideInDad wrote:
Should I bolt a grounding block onto the aluminum frame? I saw comments of no copper against aluminum but what about a steel grounding block on the chassis?
โMay-26-2020 05:41 PM
โMay-26-2020 02:36 PM
โMay-26-2020 02:28 PM
WNYBob wrote:
I think you have missed the point that there are 2 separate 12v systems in a TT. One is the TV (tow vehicle and the DMV lighting) circuit and the other is the TT. They should not be mixed.
โMay-26-2020 09:47 AM
โMay-26-2020 09:26 AM
โMay-26-2020 09:22 AM
โMay-26-2020 08:43 AM
โMay-26-2020 07:56 AM
CA Traveler wrote:
Your link sounds like a concern for corrosion which can become a problem. Good maintained grounding would do the job. 10 ga is likely over kill for the running lights ground especially for LED lights.
Are you going to use the TV to charge the trailer battery? Regardless I'd ground the 12V interior system including any incoming AC to the trailer.
Aluminum conductivity would not be a concern for me but long term corrosion can be a issue.
โMay-26-2020 07:52 AM
