1990 Holiday Rambler - Closed Problem Found
gatorcq
A couple in the John Prince park have a 1990 - 1991 HR. As usual in talking to them, they have a problem. Both of them being in there 70's or low 80's need some help. I am willing but before I walk into their coach I need some information.
Problem:
No chassis function inside the coach i.e. Head-lighs, gauges, etc.
What I need to know is 2 things:
1) Is there a battery disconnect switch circuit ?
2) Is there a battery control center box?
My skills in trouble-shooting are excellent, so I would like item 1 and 2 answer before I offer to help. I hate crawling around when someone else may have the answers I need.
Thanks
dale
Dale & Susan
DaGirls II Rv - Dakota & Tilly Traveling Companions.
2008 Alfa Gold, 2015 Ford F150 XLT
Roadmaster and Air Brake System
1600 Watts, Magnum Inv/Chg&Solar
800 Lithium Battery
DaGirslRV Blog
9 REPLIES 9
enblethen
Thanks for the update!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
gatorcq
Positive post clamp -
Dale & Susan
800 Lithium Battery
DaGirslRV Blog
j-d
Battery cable would have been my first guess, unless the owners had gotten to dinking with switches and control panels, which you seemed to suspect.
Anyhow, CONGRATULATIONS! Good Christmas gift for those folks!
EDIT: The Positive/Hot or the Negative/Ground? I'd hate to see'em get a wrench between the Hot and Coach Body because they were working the Hot and hadn't disconnected the Negative.
gatorcq
First, wish to thank everyone for there posts. This made my job easier. The post allowed me to go armed into an unknown camp.
Now you are all wondering what the solution is.........................................................................drum roll please.....................................................................
Ready for this ?????????????????????? A bad..................B+ cable clamp on the battery.
When he tried to start, everything would go dark or shut down.
The clamp had been replaced, but the clamp had become corroded and rusty. So I think he will be happy as soon as he replaces the clamp. I have already prep the cable for him.
Again thanks to everyone.
Dale & Susan
800 Lithium Battery
DaGirslRV Blog
johnhicks
In my 93 HR DP the chassis battery switch is in the driver side rearmost bay.
-jbh-
gatorcq
Thank you and that is what I looking for. A good place to start. I will be going over on Friday to take a look
Dale & Susan
800 Lithium Battery
DaGirslRV Blog
Fishinghat
I have a 1993 HR Navigator, and my electrical switches are in the electrical bay in the front on the driver's side. This is for the house and some of the chassis.
The main panel for the chassis is under the battery compartment in the rear on the passenger's side.
Holiday Rambler Navigator DP, Hummer, and Honda VT1100C Shadow
enblethen
Yes, there should be a battery disconnect. Switch could be on dash or near the entrance door.
Yes, there should be a battery control center. Location will vary on chassis.
Yes, there should be a 12 volt DC circuit breaker adjacent to the batteries or in the battery control center.
Bud
USAF Retired
Pace Arrow
j-d
You're right. Anybody trying to help will need lots of info. Apparently "House" electrical functions are OK, it's "Chassis", Right? If so, please obtain at least:
What is this thing? Sounds like it might be a DP. If so...
Chassis Model
Engine Info
Battery Info
Coach Series and Model
There may be more, but this could help get the ball rolling.
Thanks on behalf of these folks, for being willing to help!
