The RV Snowman wrote:
MY generator keeps shutting off from a malfunctioning oil cut off switch. has anyone here cut the wire from the switch and had their generator run again?
Why would you disable a safety switch?
I do not know which Onan you have so I cannot help for sure but; Some older Onans had a problem with foaming oil making the pressure switch shut the engine off. Onan's cure was to run the unit 1/2 to one quart low to stop the problem, Onan even had a new dipstick made to show the engine full of oil with one quart missing. Is yours one of them?
Maybe someone here will remember which model it was.
Traveling with my best friend, my wife in a 1990 Southwind
