Sep-11-2016 06:32 PM
Sep-13-2016 08:33 AM
Parrothead Mike wrote:ECO mode will kill the already weak 12v charging. ECO mode does not affect 120v output for charging.
OP here - Thanks for all the excellent input. You're right, I need to understand the charging/battery/converter issue better. I've never been much at electronics.
At this point I think I'm going to take my Schumacher battery charger along as a back up for this weekend. Of course I'll first try charging the usual way, but use the charger if that doesn't work. A longer charge will also help. One thing I did while charging when it failed was I switched over to the Eco feature and that definitely didn't help the charge I was hoping for.
Thanks again everyone!
Sep-13-2016 08:21 AM
road-runner wrote:
If there's no "surge protector" type of device in the RV blocking the AC to the converter, then I'd suspect something like a bad minus connection from the converter output, causing the AC bond to carry the converter's DC output, or alternatively an open neutral at the converter, causing the ground wire to carry the neutral side of the AC power.
Sep-13-2016 07:56 AM
Sep-13-2016 04:45 AM
road-runner wrote:I'll agree with Mr. Wizard here. If there's no "surge protector" type of device in the RV blocking the AC to the converter, then I'd suspect something like a bad minus connection from the converter output, causing the AC bond to carry the converter's DC output, or alternatively an open neutral at the converter, causing the ground wire to carry the neutral side of the AC power. Easiest way to find the sure answer is to check for AC power at the converter's plug, or run an extension cord to connect the converter directly to the generator.
You really should share your expertise with WFCO tech support so that you can correct them. The WFCO in one of my trailers will not pass convert 12v from my Honda 3000, UNLESS THE GROUND & NEUTRAL ARE BONDED. The same with a neighbor. Remove the bond plug = fail. Reinstall the bond and it works. Tech support advised contrary to your remark so contact them and advise that your advice supersedes.
I have nothing else in between the trailer plug and the generator, so please advise why it fails.
Sep-12-2016 08:14 PM
Sep-12-2016 07:26 PM
MrWizard wrote:
Some of this is going way off course
The no bond generator is not and never has been a converter problem
FYI
I have used wfco converters with inverter generators, open frame, and Onan
Never ever a ground conflict
Sep-12-2016 02:23 PM
Sep-12-2016 12:22 PM
EV2 wrote:bikendan wrote:
could have tripped the resettable circuit breaker hidden along the A-frame.
then if the OP was using the converter to charge, the battery wouldn't be getting charged.
If so, how did it reset itself?
Sep-12-2016 08:46 AM
Sep-12-2016 08:18 AM
Sep-12-2016 07:30 AM
mbopp wrote:
My old Elixir, two WFCO's, and an IOTA-55 all ran off my Honda 2000i.
Sep-12-2016 07:19 AM
Sep-12-2016 07:09 AM
Sep-12-2016 06:37 AM
