โSep-09-2019 01:49 PM
โSep-10-2019 05:32 PM
dougrainer wrote:
IF the CCC wall tstat is NOT in an overhead cabinet the CCC wall tstat is Zone 1 temp sensor. You have all the wiring to do a new change out. I will bet the original replacement, the Penguin was a 10 button control board and will not work with the 5 button and that is why they installed a new tstat in the bedroom. Anybody that did this should NOT be working on RV's. If you buy 2 new Penguins, they will have the onboard control boards already and you just purchase a 10 button wall CCC tstat. ALL the wiring to connect is already there. Doug
โSep-10-2019 03:56 PM
โSep-10-2019 06:41 AM
dougrainer wrote:
Are you the original owner? I ask Because we sold Newmar from 1994 til 2008, and hundreds of DSDP's. NONE--NONE came from the factory with 2 wall tstats. They came with the standard(your year) 5 button Dometic wall CCC Tstat. You then had the rear Zone 2 with the remote bedroom temp Thermister. Now, believe it or not, over those early years I saw a few Newmar's with just 1 Roof AC (DSDP Diesel and Gas model). Usually sold to dealers in the NE and NW. So, is it possible your model came with 1 AC and somebody added an extra and used a wall tstat? OR, there was a problem with the original set up and the Tech that was trying to fix installed that 2nd Bedroom wall tstat? My point being, you should have the communication wiring in place for easy change out to new Penguins and new 10 button CCC wall tstat. I will bet you also have the Bedroom Rear remote Thermister someplace in the Bedroom on the wall. Doug
โSep-10-2019 05:03 AM
โSep-09-2019 03:52 PM
โSep-09-2019 03:37 PM
โSep-09-2019 03:17 PM
โSep-09-2019 01:55 PM
