โSep-19-2018 08:02 PM
โSep-20-2018 10:31 AM
newlee wrote:
I would check for a loose neutral wire.
โSep-20-2018 10:30 AM
dougrainer wrote:
Odds are the Progressive EMS is the problem. Is this hardwired or can you just unplug it and run direct? Doug
โSep-20-2018 10:07 AM
accsys wrote:
If your EMS believes your input voltage is high or low, it will shut the AC down and then after a while will reset and try again. Have you checked your voltage at the pedestal. You may have too high a voltage. If it is borderline as your post indicates, you can bypass the EMS with the little slide switch on the unit. I wouldn't do this unless absolutely necessary as it bypasses the circuitry on the EMS and surges or other electrical problems will get through. If it is erroneously reading a high voltage when the voltage is normal, the EMS could be bad and need repaired or replaced.
โSep-20-2018 10:05 AM
Bud
USAF Retired
Pace Arrow
โSep-20-2018 09:58 AM
Mandalay Parr wrote:
You need to get an electrical person with a meter to find out what actually is going on.
โSep-20-2018 07:08 AM
Bud
USAF Retired
Pace Arrow
โSep-20-2018 06:49 AM
dougrainer wrote:x2
โSep-20-2018 06:19 AM
โSep-20-2018 05:00 AM
โSep-19-2018 09:04 PM
โSep-19-2018 08:55 PM
