โJun-06-2017 03:00 PM
โJun-25-2017 05:54 PM
โJun-24-2017 07:30 AM
โJun-24-2017 06:47 AM
โJun-23-2017 08:11 PM
time2roll wrote:
Very nice. My PS1800 ran my 13.5 Dometic air just fine. Not sure why you would have trouble.
I would heat shrink those cable ends to seal them up before the corrosion starts.
โJun-23-2017 06:56 PM
โJun-23-2017 12:09 PM
โJun-23-2017 11:48 AM
โJun-23-2017 11:22 AM
โJun-23-2017 11:07 AM
โJun-07-2017 08:11 PM
MrWizard wrote:
I have run a hand held grinder with my inverter, also a skill saw at 12 amps
The MW uses more per than either one,
โJun-07-2017 08:01 PM
โJun-07-2017 07:24 PM
MrWizard wrote:
how big a compressor are you going to carry around
how big a jack hammer
how big of an electric arc welder
you will never draw 200 amps continuous load aka 2400,
you will never hit 2800 for more than a split second (IF EVER)
you don't have have anything that is going to draw 2400w
certainly NOT 2800w
that inverter won't carry 2800w more than a few seconds even if you had 10 batteries, thats a surge rating, aka motor start
its an 1800w inverter, thats max full load
โJun-07-2017 03:43 PM
DiskDoctr wrote:MrWizard wrote:
A 200 amp shunt and meter, is going to more accurate at average RV power loads than a 500 amp shunt and meter
But what about the overload situation?
Won't I be limiting myself to 200a, instead of the inverter's max capacity?
โJun-07-2017 03:12 PM
