3000 watt inverter/converter installed backward
wdarlenew
What happens if my 3000 watt inverter/converter is installed backwards in my RV? What am I looking at for repairs now?
1 REPLY 1
naturist
Not sure what you mean by "installed backwards." Do you mean the DC leads connected to the AC wires and/or the AC leads to the DC input? Or do you mean DC negative and positive leads reversed? Not that it matters, I suppose, as any of these would likely burn out key components in the inverter, likely rendering it junk.
