โApr-16-2018 03:48 PM
โApr-17-2018 07:04 AM
map40 wrote:
I installed a 50 amp outlet with 30 amp wire and 30 amp breakers. I have 7 RVs, and none of the 50 amp units use more than 30 per leg, so this configuration worked great. Just keep in mind that the maximun output per leg will be only 30 amps, any more will trip the breakers.
For all the ones that tell me that what I did is wrong, here is a kicker; I normally end up plugging a 50 amp coach in each one of the legs of the 50 amp plug (with a 50 amp Y adapter), all AC units running (in Florida summer) and never tripped a breaker or heat up the cables,
โApr-17-2018 06:26 AM
LarryJM wrote:BFL13 wrote:
Be very careful to stick to 120v and not get mixed up with household 240v like with a stove or dryer. Get lots of sad reports of people hooking up "RV" plug-ins at stick houses that turn out to be 240 and they fry everything in their RVs.
ISTR the 30 amp cord in a 30a RV is made up of #10 wires, but no idea what a 50 amp cord has.
Your post is not only very misleading, but INCORRECT. This thread is about 50A service which is in fact exactly the same as a 240V home service like an electric range uses.
The real confusion comes from the 30A service where a typical 30A home is 240 whereas the 30A RV is 120.
Larry
โApr-17-2018 06:13 AM
โApr-17-2018 05:55 AM
โApr-17-2018 05:02 AM
โApr-17-2018 04:49 AM
โApr-17-2018 04:20 AM
โApr-16-2018 09:34 PM
โApr-16-2018 07:12 PM
โApr-16-2018 06:55 PM
โApr-16-2018 06:02 PM
Artum Snowbird wrote:
Of course much of this depends on what you plan to use while visiting those friends. The idea that you would need a full 50 amp circuit while you stay is excessive, but if you need to have two air conditioners running and more at the same time, well you might need it.
And Hi from Campbell River. Will you be taking the country by force again this year?
โApr-16-2018 05:56 PM
โApr-16-2018 05:37 PM
โApr-16-2018 05:36 PM
