Jun-29-2019 07:41 AM
Jun-29-2019 10:27 AM
Jun-29-2019 10:13 AM
Jun-29-2019 10:10 AM
CA Traveler wrote:
However consider: If the extension cord doesn't have the standard 30A female RV plug install one and buy a 30/50 adapter. Another option is buy a 50A extension cord and adapter, yes more expensive and heavy but allows for connecting to a 50A pedestal when it's to far from the RV. I occasionally run into this as there is absolutely no standard pedestal placement including even located on the passenger side.
Jun-29-2019 10:09 AM
Jun-29-2019 09:59 AM
dryfly wrote:
Let me rephrase my OP. I fully understand AC split phase wiring of the 50 amp supply. I guess I don't understand how combing L1 and L2 in the dogbone adapter supplies 120 volts. Seems like it would produce 240 volts.
I'm asking this because instead of buying a 50 to 30 amp dogbone adapter, I want to take an old 30 amp extension cord and modify the trailer end with a 50 amp female plug, in essence build a 25' adapter.
Jun-29-2019 09:58 AM
Jun-29-2019 09:46 AM
pianotuna wrote:
On a fifty amp--I do recommend a top of the line energy management system that may detect an open neutral.
Jun-29-2019 09:41 AM
Jun-29-2019 09:14 AM
Jun-29-2019 08:58 AM
Jun-29-2019 08:02 AM
Jun-29-2019 07:51 AM
Jun-29-2019 07:45 AM
