โAug-08-2017 04:50 AM
Walter & Garland - Camp Canine caretakers
Miss Inga (aka "Shorty") - 10 y.o. old GSD.
Gen. Gretchen - Joined Rainbow Div., June 27, 2017 at age 13
Gen. Missy - Joined Rainbow Div., June 11,2006 at age 12
2018 Montana HC305RL 5th wheel
2018 Silverado HD 6.0L
โAug-09-2017 01:45 PM
pianotuna wrote:Seeing as how this connector is strictly for use here at my house, I'm not gonna worry too much about finding a replacement "on the road". When I am actually camping, the normal shore cord will be used.
Secure yes, but it has much less actual contact area. Not a problem until high amperage devices are in use.
The other issue is finding one "on the road" vs going to Walmart for "standard" 50 or 30 amp connectors. You may be hard pressed to find a replacement.Bill.Satellite wrote:pianotuna wrote:
Twist lock would not be my choice for an upgrade.
Interesting post. Why not? It's likely the most secure shore power connection you can make.
โAug-09-2017 01:16 PM
โAug-08-2017 02:54 PM
Hornnumb2 wrote:DOTLDaddy wrote:
Thank you all for your suggestions. Since this electrical connection is strictly for maintaining the battery, I think I will just stick with my present 15amp outlet.
Anyway, I found this at Amazon, which looks to be exactly what I was looking for:
https://www.amazon.com/Power-TechON-RVA4016-Twist-Adapter/dp/B01K0MBYDE/ref=sr_1_1?ie=UTF8&qid=15022...
Just add a battery cutoff switch then no plug is necessary.
โAug-08-2017 02:53 PM
โAug-08-2017 02:22 PM
โAug-08-2017 01:56 PM
โAug-08-2017 01:33 PM
โAug-08-2017 11:27 AM
โAug-08-2017 10:15 AM
โAug-08-2017 08:56 AM
โAug-08-2017 08:31 AM
โAug-08-2017 05:57 AM
โAug-08-2017 05:40 AM
โAug-08-2017 05:23 AM
