55a 12vdc power supply....$15
MrWizard
Moderator
Moderator
spotted this at allelectronics, for $15 seems like a real bargain
this is the label, 650w max out put
be nice if it is adjustable some place on the circuit board
insides
yes $15
about 5" wide 4"deep/height, 14 inches long these are estimates, i did not measure them
searching the web i found this
http://l7inc.us/info_TPD5A-1D
and this.. it appears to be the 'current' version
12vdc 600w power supply
I can explain it to you.
1997 F53 Bounder 36s
14 REPLIES 14
MEXICOWANDERER
If you saw the garbage barge output of a standalone RV converter on an oscilloscope, you could appreciate the 15 millivolt ripple and exceptionally tight droop as found on this unit's spec sheet. It is a power supply. A battery charger is not a power supply nor is the reverse true. A power supply develops exceptionally clean power.
time2roll
I like techno stuff too but it needs a purpose to spend money.
I bought something like this to run my model train at Christmas:
Voltage always sags on model train controllers but not this one. Amps rise and fall as it goes over the trestle. Holds speed much better as power increases when climbing and drops off when decending. Great for a bench power supply also.
Good luck with the $15 12v supply.
MrWizard
Moderator
Moderator
if it turns out to be adjustable
i may go get one just as a backup to have on hand
and tinker with
dw says i have too much 'junk' now
shes right, but i can't stop my 'affliction' not an 'adiction'
i'm afflicted with techno tinkering
SCVJeff
Chris Bryant wrote:
If it is really 12 volt output, it will not charge a battery, but my question is the 20-30v battery input. That might be the thing for folks with 24 volt chassis setups, or if it is adjustable, just the things for a pv setup.
If this is like any other Power One supply I have had over the last 30 years, it has a pot that tops out around 15V, and probably has ext. sense points as well. Hopefully they will still have them on Sat.
The 24v input is interesting. This must have come out of something with fail-over service. Never seen that on a Power One
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
KJINTF
$15.00 is a good deal for a shop 55amp 12Vdc supply
I use a different approach for low cost shop power supplies
Currently in use are about 8 tossed out aka junked converters, todays throw away society it's easier to buy a new one for most folks. They were all repaired for less than $5.00 each in parts and are now fully operational. The 100amp WFCO with a nice pendant easily switches between 13.2 / 13.6 / 14.6 and does a great job when high current is needed.
wa8yxm
I am hating my computer this morning.
That appears to be a "Single Stage" Device, might be useful to provide power but NOT for battery charging and maintenance.
Chris_Bryant
-- Chris Bryant
SCVJeff
RJsfishin wrote:
What would you use it for ? Probably can't be used for a battery charger/converter,
If I had one, I'd let you have it for 10 bucks ! ๐Ÿ™‚
Its a 55A 12V supply. How can that not be a converter? If you wanna buy one and sell it to me, I'm there. Otherwise I'm off to buy one Sat morn. on the way to the RC field
Jeff - WA6EQU
westend
Very sweet deal! If I didn't have a couple of regulated supplies already on the bench, I'd be all over that.
I do see a couple of trimmers on the board but I doubt they are adjustable for output.
'03 F-250 4x4 CC
RJsfishin
Rich
Gene_Ginny
Thanks, that is what I thought. There used to be a store near me that had stuff like that, usually closeouts on the last few in stock to clear their shelves. That looks like a super good buy.
Gene and DW Ginny
[purple] 2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363[/purple]
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
MrWizard
Moderator
Moderator
i was in store yesterday/Tuesday
spotted them on the shelf and took the pictures
they have lots of stuff thats NOT in the catalog or web site
here's the ph# 818-997-1806
Gene_Ginny
I looked at allelectronics website and can't find it. Did you see it online or was it in the store?
Gene and DW Ginny
Golden_HVAC
Interesting.
I wonder if you order one, if the seller will state the price is wrong, and not send it for such a low price. I had that happen when I was ordering some 24 LED panels. The seller claimed the price was wrong, they wated about twice as much as they stated in the ad, yet said for the stated price they would send 9 LED panels (instead of 24 LED). I had to cancle that order and place it with another company.
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a
Porsche or Country Coach!
I havn't been everywhere, but it's on my list.
Kangen.com Alkaline water
Escapees.com
