6 Volt RV batteries
Willcamp4
I have been a fan of Trojan batteries for many years. I have a 2005 Alpenlite and use a bank of four batteries. When the trailer was new I installed a set of T-105s that lasted about 7 years, and I installed a new set. It seems to be time to replace them again as they won't stay charged above about 12.1 volts. The only issue I have is that the Trojans have gotten SO EXPENSIVE. What I'm wondering is whether there is another brand/battery that is reasonably priced and dependable.
Willcamp4
2012 Ford F-250 Super Duty, Crew Cab, Lariat, 6.7L PSTD, Air Lift rear suspension.
Alpenlite Valhalla Limited Fifth Wheel, two Solar panels, four six-volt batteries, two Honda EU2000i generators
52 REPLIES 52
bpounds
BFL13 wrote:
"...and I installed a new set. It seems to be time to replace them again as they won't stay charged above about 12.1 volts"
An amazing statement! If they took a long time to get that bad, and you kept using them till now, then it would seem you might only need one 12v battery to get the job done. Why buy four new 6s if you only actually need one 12v batt?
This is all very peculiar!
Please explain. It would seem you are saying that long battery life means he has more battery capacity than he needs. Or perhaps you meant that he survived on weak batteries for a while, and that this means he has more battery than needed. Neither makes much sense.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
IAMICHABOD
Costco would be my choice,6 years and still holding charge and they get a lot of use.
I checked Sams and Costco they both had them at about the same price the ones at my Costco were newer,only 2 months old and Sams were 6 months or more old some were 9 months old.I think in my area Costco sells more and quicker so they turn over faster.
I would check around.
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
beemerphile1
I get my GC2 (6v golf car) batteries at Sam's Club. I plan (usually get) a minimum of 7 years use.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
twodownzero
Sams club is your friend.
philh
what brand convertor/charger?
Lwiddis
Trojans worked great for seven years and you want a different brand to โ€œsaveโ€ a few upfront bucks?
BFL13
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
enblethen
I get 6 volters from Costco. About $80 per battery.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
