$.80 solar panels
EldIr
A while back, maybe months, maybe last year, someone posted a link to solar panels for 80 cents per watt. I've tried searching but can't find it. I've also looked around eBay and Amazon and can't find anything even close to $1 a watt. Anyone have a link?
'01 Burb 2500 4x4 496/4.10 (3.73 effective w/ new tires)
'94 Jayco 300BH
35 REPLIES 35
Tom_M1
Check Sun Electronics
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
BFL13
A cabin could be with no 12v systems like an RV has, freeing you to go to higher voltage battery bank and inverter to then make 120v for lights, fridge, etc It seems higher voltage panels are generally cheaper per watt.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
KD4UPL
Just about any solar panel sized over 225 watts should be around $1 a watt or less. I'm a residential solar contractor and I can buy some cheaper brands in quantity for under $.70 a watt. That's usually pallet quantities with incur a lot of freight charges.
If your looking at smaller 100 watt panels then you won't find many that cheap.
EldIr
JiminDenver wrote:
What size?
Solarblvd.com has 235w panels for $158 + shipping.
Don't know what size yet. This is for our new cabin not the tt. Roof is going on next week so we're starting to look at what the solar install will be. Just remembered seeing that link a while back.
'94 Jayco 300BH
JiminDenver
What size?
2011 GulfStream Amerilite 25BH
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 2200w inverter generator
time2roll
12v was probably a close out. Less than $1 per watt is tough.
lots of 24v panels under $1 per watt, MPPT controller required.
