โOct-08-2016 10:31 AM
โOct-18-2016 07:47 PM
time2roll wrote:
Regular thermostat will not work. This one has a digital signal to the control box up in the ceiling in addition to 12v power. Furnace control is up there also.
Here is my conversion to use this digital. May help see how it works.
http://forums.woodalls.com/index.cfm/fuseaction/thread/tid/26820366.cfm
โOct-18-2016 07:25 PM
โOct-18-2016 07:14 PM
โOct-10-2016 03:26 PM
smkettner wrote:Charlie D. wrote:Is the fan set to automatic? I have a Dometic single station digital and when the air conditioner switches from low to high or high to low fan speed it does seem to turn off and back on within a brief moment. I believe above 3 to 5 degrees of the set point the air runs on hi and as it approaches the set point will switch to low. I have also experienced it when it will cycle up and down a bit before it decides to stay hi or stay low.
Edited to say: 4 years old and has original Dometic digital thermostat.
I am calling normal even if a bit quirky.
โOct-10-2016 12:22 PM
โOct-10-2016 11:42 AM
โOct-09-2016 09:45 AM
sdianel wrote:
a tech told us to leave the fans on "high" at all times in hot or humid weather. He said that the unit needs the air flow to prevent icing which will shut down the compressor. Since we have been doing that our 2 AC's have been working fine. If you have 2 AC's both fans must be on high. You can also try a thermostat reset. (in your manual).
โOct-08-2016 09:23 PM
โOct-08-2016 11:00 AM
โOct-08-2016 10:53 AM
โOct-08-2016 10:48 AM
