A different flashlight question
Dave_H_M
i am looking for a led light for the camper. I had a perfect one and dropped it on the concrete and it lost its mind. :S
I want one with 3 C bateries and a sliding focus capability.
here is the kicker. i want one that when you push the button it goes from what you had it set on (hi, low, etc) to off. I do not want to cycle through all the modes.
On the one I liked you could cycle the modes quickly to get to the one you wanted. When finished you could push the button and it went off.
i got the last one as a pair and gave one to the daughter from Costco. They stpped stocking that gen.
thanx
26 REPLIES 26
SaltiDawg
N-Trouble wrote:
Screw batteries go rechargeable...
Streamlight Stinger LED HL - best little flashlight I have ever owned. Not cheap but also never have to buy batteries. Serious light output. Used by many in law enforcement.
http://www.streamlight.com/en-us/product/product.html?pid=273
I also have a streamlight... in a pinch it will serve as a billy club also. :C
Lots of cops carry them.
Dutch_12078
thanx
We have a pair of Duracell LED flashlights that use 3 'C' cells and work exactly as you described. They can be shut off from any mode without stepping through the other modes simply by holding in the button for a few seconds.
Duracell Durabeam Ultra High Intensity Tactical- 500 Lumen Flashlight
Dutch
2001 GBM Landau 34' Class A
MEXICOWANDERER
I wanna CREE 5-watt that uses 3-D cells. I am so tired of manually recharging my 7.2 volt NiMH 190 LED floodlight. Love to find 15 amp hours of 7.2 lithium at an affordable price.
trail-explorer
I use this one, which can user CR123 or 18650 rechargeable cell:
http://www.deltabravotactical.com/eagletac-T200C2.htm
I am running it with an 18650
Bob
NinerBikes
Mexicowanderer reread my post, double check all the links, for color of light beam.
landyacht318
There are some dangers with extracting the 18650 Lithium cells from an old laptop battery pack. You cannot just treat lithium cells like you do any other battery type.
Of any failed 6 or 9 cell laptop battery pack there is at least one cell which might be dangerous to recharge and put into use.
Check the voltages on each cell and label them once you separate them from their series parallel interconnects, and be dang careful when separating them and monitor them for heat when charging them individually.
Try and Keep the plastic of the laptop battery casing intact, as they make a great holding case for all the extra cells you will have.
Read this if considering doing so
My extracted cells were only rated at 1900Mah. I have some 3400mAH panasonic cells, and honestly, I grab these first as their run times are significantly longer. The extracted cells are used when the task does not require full brightness of my light for as long.
NinerBikes
MEXICOWANDERER wrote:
It looked great Niner, until i got to the part
LUZ AMARILLO
Mode de estacionamiento de Wal-Mart
Walmart parking lot high pressure sodium orange.
My eyes do not do well in "warm" white lighting never mind the lighting quality on the San Francisco Bay Bridge.
¡Pero Mil Gracias Para Su Cuido!
That is the color of the outside housing, a light yellow, or gold color, not the LED's, which are cool white in emitter color. The trim is silver color, not the body.
I bought one of these a while back, complete kit, and I can assure you, the lighting color is cool white, probably 5000 to 5400K temperature.
Same light in kit form
MEXICOWANDERER
LUZ AMARILLO
NinerBikes
Being an oldfart I need a flood light at night so I don't trip and break my other arm. But I've not yet found a powerful C or D cell cylindrical hand flood lamp. I do have Tenergy rechargable cells.
Big Azz Flood LED that runs on your 18650 batteries out of your laptop... or buy 4 new ones and a ch...
Another seller, another description
18650 charger
Or get a combo kit.
4 batteries and charger.
Dave_H_M
I do not disagree, but that is out of my league. I did not realize the spectrum of the led lights out there.
MEXICOWANDERER
N-Trouble
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
Dave_H_M
Harvey, What do you use to charge the battery for that one.
If simple enough, I am gonna try it.
rexlion
Mex, made very sure you have a good charger that terminates promptly at 4.2V. But you probably knew that.
I'm a flashaholic, but I really don't know any C cell lights. The better quality flashlights use other types of cells. I like the Nitecore EA41; 5 light levels from 1 lumen to 1020 lumens, on 4 AA cells; on-off switch plus separate mode switch lets you decide whether to scroll through levels or just turn on-off.
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
