โJul-22-2014 01:12 PM
โJul-26-2014 10:43 PM
โJul-26-2014 10:26 AM
โJul-24-2014 08:11 AM
โJul-24-2014 06:47 AM
Almot wrote:
It should be noted that between cheap Chinese UB/UPG and expensive Lifeline there are US made EastPenn/Deka and Full River, a lot cheaper than Lifeline.
โJul-23-2014 07:31 PM
โJul-23-2014 07:14 PM
โJul-23-2014 06:04 PM
โJul-23-2014 03:00 PM
โJul-23-2014 02:26 PM
mena661 wrote:Actually, two temperature compensators, one for the solar charger and one for the charger in the inverter. Works well.
.... It seems a lot of people here use solar in conjunction with AGM's so my guess is they're using temp compensation.
โJul-23-2014 01:28 PM
โJul-23-2014 12:59 PM
โJul-23-2014 12:36 PM
kccwoodworks wrote:AGM's DO gas if you overcharge them. And "overcharging" can be using too high a float voltage in hot weather. Another member here confirmed that in his testing (HiTech). You don't want AGM's to outgas. Keep your voltages close to manufacturers recommendations and use temperature compensation. It seems a lot of people here use solar in conjunction with AGM's so my guess is they're using temp compensation.
What no one has mentioned yet is AGM's don't gas. They don't need to be vented therefore are safer. The only place for batteries in my van is inside where a wet cell would be dangerous.
โJul-23-2014 12:22 PM
BFL13 wrote:
It is a specialty situational thing whether the AGMs would be worth it to YOU.
Besides the situation where you cannot get at your batteries for hydrometer and water level checks easily, making AGMs better, the other thing that really came to light in previous threads here was (as mentioned above) little voltage drop under heavy load.
โJul-23-2014 09:57 AM
pigman1 wrote:You got that right. I got pretty weary of the maintenance of watering. It takes some big pockets to buy your way out of it, but it's really nice once you do.
The big selling point for me is no need to add water, and absolutely no corrosion....EVER.
