A Tip For Folks Who Are Trying To Help Others With Batteries
MEXICOWANDERER
I slip on my galoshes and wade deep deep deep into battery issues. OPs sometimes complain they don't want to learn the technical side.
So maybe it would be best to simply stick to reporting your favorite brand of charger to be used with a generator, how many hours of runtime to recharge his bank and then list the downsides (a plus versus minus
list)
There will be casualties. Like a driver who insists on eating a sandwich while texting. They choose to have a lifetime of 2-year chew & spit batteries.
A person would think I immerse myself in battery care insanity with my bank...
Is this over indulgence?
24 cells at 24.2 volts
Start generator let it warm up.
Twist an Intermatic timer knob to say 4.5 hours
When I hear the generator unload at 4.5 hours I stroll up the hill and shut off the engine.
Every week I take a hydrometer reading of the weak sister cell.
28 REPLIES 28
MEXICOWANDERER
Yep
Some people demand dragging Behind them with 300 channels of TV. 5-bar 5-G service, a bidet, 24-hour instant Kerug coffeemaker, and wonder why they can't boondock on a couple of scumbag grade 3 cell batteries.
They demand 'effortless'. Send their kids to school as a babysitting entity and then scream when the school spits out effortless miscreants and effortless mom & dad are forced to put the bail bondsman on speed dial. Effortless.
Employment today is no harder than it was 50 or a hundred years ago. But people are a **** site lazier.
pnichols
list)
David .... that's about what I do when camping except for the walking up a hill part (absorption refrigs don't like hills): Run my twin AGMs down to 50%, idle the V10's 130 amp alternator for one hour to dump in a lot of amps, then run my 650 watt portable generator and the RV's stock 13.6 volt converter for 4-5 hours to bring the AGMs up to 90% or so full.
This procedure works like a K.I.S.S. champ for me ... sun or no sun. I guess I'm using a V10 engine and it's alternator, a small generator, and a stock converter to approximate your approach. (I retired from my EE career a long time ago and am interested in things other than over-messing with electricity, now.)
2005 E450 Itasca 24V Class C
mordecai81
BFL13 wrote:
mordecai81 wrote:
It's kinda funny, but I'm equalizing my 155 amp 12 volt right now.
Which brand /model of battery is that? I know a T-1275 is 150AH, but I don't know of a 155AH--would like to know in case I ever go that route again.
I see a 65 amp Boondocker in the picture. Is that with the adjustable voltage between 13-16.5 (same as PowerMax "LK")?
It's a USBattery 12v scrubber battery. My Boondocker is the manual version of the LK, I think. It does it's initial voltage setting for 15 minutes then drops down 1.0v so I have to dial it back up at that point. Kind of annoying, but workable.
mordecai81
full_mosey wrote:
Are you stirring or cell balancing?
HTH;
John
Both, but mostly balancing. There has been a consistently weaker cell in this thing since new. It comes up to 1.270 if I hit it hard enough but it sure is stubborn about it.
MEXICOWANDERER
  • I've written this before
  • You need an ammeter to make this easy
  • Remove battery caps
  • Charge a cycled battery
  • If no bubbling of electrolyte is noted even after prolonged "charging" the battery is not charged
  • period.
BFL13
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
full_mosey
HTH;
John
mordecai81
mordecai81
I fall into the "Pro MEX group", I guess. He got me really thinking about battery fundamentals some time ago and I've carried on from there by reading up on battery charging and maintenance from whatever sources I can dig up. I come at MEX's posts the same way I approach a "New Yorker" magazine one panel comic - knowing that there will be some posts that I simply won't get, but that doesn't bother me 'cause I like a challenge even if I don't get all the way to clarity. YMMV, of course.
MEXICOWANDERER
As electrolyte temperature drops maintenance voltage must increase to keep battery potential in stasis. An amperage inappropriately high at 80F may be perfect at 50F and inappropriately low at 30F
Several years ago I kept online records HERE on this forum of a generic 12 volt UNregulated 700 ma transformer. At 700 ma at 70F it maintained 13.45 volts. Th battery was a so-called deep-cycle Wal-Mart group 29
At 708 ma it maxed out. Temp was 50F and voltage had fallen to 13.18
In July voltage was 13.6(forgot the second digit.
Cell Activity was verified with a hydrometer.
During a narrow ambient temperature spectrum applied voltage was correct.
For 24/7 maintenance floating temperature is critical.
But battery tender products do an admiral job with temperature compensation. Within their amp hour capacity span.
Constant current maintenance is never appropriate. A 1,5% amperage to amp hour capability is acceptable.
MEXICOWANDERER
MEXICOWANDERER
If someone suspects they know of a simpler AGM battery protocol than
Connect to a charging source that maintains 14.5 volts and can restore to 100% charged state from 50% state of charge in 6.5 hours and you have found "The Perfect Charger" for AGM. Timer controlled limit would safeguard the system. This would not be enough control voltage wise for elk hunting or Colorado river camping in July.
I am tasking myself with finding variable resistance pads for use with Megawatts for use with auto voltage control from -15F to 115F It eliminates manual switching. The thermistor would be lost if the battery were to become useless.
MEXICOWANDERER
OK too many errors, period. Concorde, Lifeline, And Trojan offer great informtion. Battery University offers excellent advanced hints, tips, and equations. There's a tip ๐Ÿ™‚
red31
Here's a tip, keep your prejudice to yourself
Too many ambiguous statements to believe the good fellow is even college educated.
