Absorbsion Charging Wet Batteries
MEXICOWANDERER
As batteries charge, amperage will sag and voltage climbs. There is a point where solar panels can effectively replace a running generator.
Use 14.8 voltage to start out with on the generator. If you have 40 amperes max DELIVERED panel power you can shut the generator off once amperage sags to 40 amps.
11 REPLIES 11
Lwiddis
Gordon, solar trackers are cool but adding a panel or two is cheaper and much less prone to failure. So, no wager!
MEXICOWANDERER
To gain any sense of perspective between charge regimen times the voltage must remain constant, 14.8 volts from the moment you flip the switch on to the moment you flip the switch off.
Skewing the results with variable voltages and non saturation makes time savings analysis worthless -- flipping a coin is just as inaccurate.
No variable voltages please and no cheating on the 14.8 volts.
Then and -only- then can you realize an accurate answer in perspective.
This is all about generator run time ๐Ÿ™‚
time2roll
MEXICOWANDERER wrote:
Silicon carbide cells for NASA and DARPA are 167% as efficient as commercial cells.
Cost effective for outer space only.
For earthlings lower cost to expand your footprint.
MEXICOWANDERER
Remember the stories about Rolls Royce, Jaguar, and Aston Martin? I don't know if they were true or not.
But it was a snotty reply
"If you have to inquire the cost of ownership then may I suggest another marque"
GordonThree
pianotuna wrote:
And the price?
More than a golden hammer or toilet seat, typical DOD pricing.
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
pianotuna
Nomad III
Nomad III
And the price?
Regards, Don
MEXICOWANDERER
GordonThree
I wager he's working on a automatic solar tracker for rooftop RV install.
time2roll
If I get 40 amps from solar, I am not starting a generator.
Lwiddis
โ€œin hopes that will get the batteries "full" before dark.โ€
What hopes? Iโ€™m full by noon usually...3 p.m. tops...with 300 watts and no pointing.
BFL13
Mex 40 amps of solar means you have about 40/8.2 x 130 = 634w array pointed directly at a high sun.
You can't get constant amps with solar unless you can keep the array pointed and tilted just right as the sun goes by while also going up and down.
However, it remains valid that you can follow your shot of generator charging with solar for the rest of the day in hopes that will get the batteries "full" before dark.
You can extend the gen time high amps when you know the daylight time after that will be short.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
