AC fan reverb
WI_Bowhunter
Just set up camp with my Puma 30DBSS. Turned the AC on and all seemed good. Went into my bedroom in front and there is a vibration or loud reverb coming through trailer. Can't notice it in other area of trailer. With AC or just Dan on, it sounds the same. Any idea I can check while out this weekend? Otherwise I will make an appointment at the dealer since I have warranty.
Keep the Shiny Side Up!;)
2011 F150 Supercrew, 4X4 3.5 Ecoboost, 145" wheelbase, 3.73 gears, Max trailer Tow package
2014 Puma 30DBSS
Equali-I-Zer WD Hitch
3 kids and 1 DW
3 REPLIES 3
camperpaul
WI Bowhunter wrote:
Well, I took the cover off inside and the 4 bolts were pretty loose. I used. A hand driven nut driver and tightened them quite a bit. I did not over torque them i hope. I did nut turn them in as far as I could, but decently snug. This did not solve the problem completely. I'll check the topside tomorrow in the daylight. I think tightening it helped control the shaking, but it seems the fan is not valanced
A little Loctiteยฎ on the bolts will prevent them from loosening.
The fan may be just dirty and cleaning it will correct the imbalance.
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
2011 2500HD 6.0L GMC Denali (Gasser)
WI_Bowhunter
2014 Puma 30DBSS
3 kids and 1 DW
therink
Remove inside cover (4 screws) and try tightening the 4 lag bolts that secure the AC unit to the roof. Should not tighten more than 1 turn each or could over compress roof gasket. If that doesn't work, remove roof shroud and check fan blades for unbalanced condition (mud daubers or bees nest). Have your bee spray ready. Other than that, I don't know.
Steve
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5th Wheel, 12,280 lbs loaded (scale)
2015.5 GMC Sierra Denali 3500, SRW, Duramax, CC, Payload 3,700 (sticker- not scaled yet)
Take my posts for what they are, opinions based on my own experiences.
